Technics SL-1100A: Rebuild or Buy New Turntable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-04-2012, 04:50 PM - Thread Starter
fastdart69's Avatar
I have a Technics SL-1100A turntable that I bought new back in the late 70's early 80's. It still works pretty well although it is difficult to adjust the platter speed to maintain a constant speed. I would like to know your thoughts on whether I should spend the money to completely refurbish this turntable with new components, e.g. motor, tone arm, etc. or buy a new turntable. Are there companies who specialize in these types of restorations/rebuilds? If a new turntable is the way to go, what would be represent a good audiophile turntable in the $1,000 to $2,500 range. Thanks in advance for your responses.
fastdart69 is offline
post #2 of 7 Old 11-05-2012, 05:45 AM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Ratman is offline
post #3 of 7 Old 11-05-2012, 06:30 PM - Thread Starter
fastdart69's Avatar
Thanks for the response Ratman. I would still like to know if there are experts who would be able to completely go through and refurbish this turntable. Thanks.
post #4 of 7 Old 11-06-2012, 05:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Most such projects are labors of love for the owners, because paying someone to do it right can be very, very costly.
arnyk is offline
post #5 of 7 Old 11-06-2012, 09:39 AM
Ratman's Avatar
Liked: 1027
If you have to retrofit/refurbish a turntable (motor, arm, cartridge, etc.), you may as well just get a new turntable.
Ratman is offline
post #6 of 7 Old 11-10-2012, 09:35 PM
keyboardcat's Avatar
first check the thrift stores. I always see a lot of technics stuff at them. maybe someone will donate a good used working one.
keyboardcat is offline
post #7 of 7 Old 11-13-2012, 10:27 AM
panotaker's Avatar
As an owner of two SL-1100A's, every time my pitch control starts to maintain a constant speed, I just spray the pitch control pots with a shot of Deoxit. They work good as new after that. I know the capacitors have to be changed out eventually, but I never had to do that to mine and mine have had heavy DJ use and work good as new.
panotaker is offline
Reply 2-Channel Audio
