How does this setup sound ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-23-2012, 08:00 AM - Thread Starter
datron3's Avatar
Long time lurker first time poster here at AVS looking for a little direction on my 2 Channel setup that I will be using mainly for watching occasional movies, ps3 and listening to music. I'm planning to purchase the KEF's Q900's, + eventually a sub, powered with a Marantz SR5005 or HK 3490. Should I be looking at any other devices to enhance my listening pleasure as far as cross overs etc.. The reason for the SR5005 is that it supports ARC and if I ever wanted to switch to a 5.1 setup years later I would have the ability to do so. Would either of these receivers be a decent match for the Kef's?
datron3 is offline
post #2 of 3 Old 11-23-2012, 07:21 PM
postrokfan's Avatar
Quoted: 524 Post(s)
Liked: 3132
The nice thing about the SR5005 is that it has bass management (Audyssey MultEQ XT). While a very good quality 2-channel receiver, the HK 3490 offers no bass management and the subwoofer connections are full range. Since you are planning on 5.1 later the SR5005 would seem to make the most sense. Great choice on the speakers.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 3 Old 11-23-2012, 08:32 PM
earwaxxer's Avatar
It sounds like you are off to a good start. IMO, its important at some point to decide what your emphasis is going to be. Are you going to focus on 2.1 or not? If you are looking for 'good' surround sound for movies but arent to picky on the absolute quality of stereo sound then where you are going is the path you should be on. If you have a limited budget, but want audiophile level stereo sound, it might be better to forget about the 'receiver' approach. Just my opinion. It's hard enough to tune a 2.1 let alone surround sound. There is plenty of good kit out there but you have to look at 'separates' to really get the best bang for the stereo buck.
earwaxxer is offline
Reply 2-Channel Audio
