Lines in screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-25-2012, 06:09 PM - Thread Starter
grarrsmi's Avatar
Hey guys, I have a Samsung TV model# LN46B650T1F. I have had it for a few years. I have vertical lines on the screen but not in one place. It all depends on what is on the screen. If it is a show, than its the whole screen. But if it is just the menu or something that is not the whole screen, than it is just that part for top and bottom. I do have white horizontal lines and show up as the tv warms up. When you first turn the tv on, everything looks great but after a few seconds the lines start to show up. I have read a lot about the wire connector going bad and some kind of foam to make it work but that seems to be just a few lines in the screen. Wondering if it is the T-con board. Can anyone help with this one. Would love to fix this and not have to buy a new tv.
grarrsmi is offline
post #2 of 2 Old 11-26-2012, 03:27 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 336 Post(s)
Liked: 6993
You should probably ask in the LCD flat panel forum: http://www.avsforum.com/f/166/lcd-flat-panel-displays
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
Reply 2-Channel Audio
