who owns this? Pro-ject Phono MM - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2012, 11:35 AM - Thread Starter
keyboardcat's Avatar
Is it pretty good? any other suggestions? I hear that the musical fidelity phono pre amp is much nicer, but more expensive. any other good phono pre amps under a 100?
keyboardcat is offline
Old 12-21-2012, 11:38 AM - Thread Starter
anyone heard of this one? http://www.amazon.com/Madisson-Preamplifier-Turntable-Amplifier-Pre-Amp/dp/B003UPTE4K/ref=sr_1_5?ie=UTF8&qid=1356114976&sr=8-5&keywords=phono+preamp
One person said that they like it, but can't get rid of a hum. the difference between the cheaper and better phono pre amps is a hum and less noise?
Old 12-22-2012, 10:38 AM
commsysman's Avatar
Quoted: 965 Post(s)
Liked: 522
Look at the Budget Phono preamps on the Needle Doctor website. The Musical Fidelity V-LPS is excellent.
The Cambridge 551P is another good one.
I have also heard that the Bellari is good, for $76.
commsysman is online now
Old 12-22-2012, 11:26 AM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3095
These are probably the best you can get for under $100 (and they are probably as good or better than much more expensive phono preamps).
www.phonopreamps.com
I have a Parasound Zphono preamp and really like it. It was over a $100 though ($150).
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Pro Ject Phono Box Ii Usb Phono Preamp Silver , Pro Ject Phono Box Ii Phono Preamp Silver , Pro Ject Phono Box Ii Usb Phono Preamp , Pro Ject Phono Box Ii Phono Preamp
