Marantz pm6004 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-24-2012, 04:00 PM - Thread Starter
Hotscot's Avatar
There doesn't seem as much choice here in the US as in the UK for a decent amp @ $600.
I'm looking for an integrated with remote, using with KEF Q500.
Many suggestions boil down to the Marantz pm6004.
Any suggestions for any others?
Hotscot is offline
post #2 of 4 Old 12-24-2012, 04:18 PM
Paraneer's Avatar
Quoted: 34 Post(s)
Liked: 87
If you are here in the US, here is a tip. Check the mini Magnolias in Best Buys for insanely low prices on the Marantz PM8004. You may be able to get a even better amp less than your budget for a PM6004. If the first Magnolia you check doesn't have one, ask them to call others. Merry Christmas!
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #3 of 4 Old 12-25-2012, 11:56 AM - Thread Starter
Hotscot's Avatar
Thanks for the tip.
Comparing the Marantz to any others...anyone used an Emotiva? I don't know much about American amps.
Hotscot is offline
post #4 of 4 Old 12-26-2012, 12:30 PM
Rick88's Avatar
Thanks for the tip. PM sent...
Focal 807W Red Carmin ● Boston Acoustics MSub ● Cambridge Audio Azur 651R/BD752/651P ● Music Hall MMF-5.1 ● Denon DR-M22 ● APC H15
Rick88 is offline
Reply 2-Channel Audio
Marantz Pm6004 Integrated Amplifier
