Tower Speakers, HDTV - Direct connection - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2012, 03:35 PM - Thread Starter
amerqureshi's Avatar
Have a great HDTV but the sound is terrible. Has anyone tried unhooking the internal TV speakers and wiring tower speakers directly to the TV (without using an external amp)? How is the sound?
Trying to get away with having to buy ANOTHER 5.1 amp but still getting semi-decent sound.
amerqureshi is offline
Old 12-31-2012, 04:11 AM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
You can buy an external 5.1 amp for as little as a couple hundred bucks. Alternately get a sound bar or set of powered studiio monitors like maudio 30s or 40 for about 100 bucks.
glangford is offline
Old 12-31-2012, 08:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
You didn't say which TV, but usually the power amps in TVs are pretty small.
You also didn't say which tower speakers. If they had high dB/SPL ratings (e.g. some Klipsch) they might work out if you didn't get to aggressive with the volume control.
arnyk is offline
