laptop to rotel rb-1050? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-10-2013, 05:58 AM - Thread Starter
rocky1's Avatar
I have a laptop w/windows8 that i would like to connect to a rotel rb-1050 70x2 amp.What would be the best way to do the connection.would appreciate any help.thanks
rocky1 is offline
post #2 of 10 Old 01-10-2013, 07:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Here's your first step:
http://www.seismicaudiospeakers.com/mini-stereo-phone-splitter-cable-p/sairtsy6.htm
The little black plug goes into the laptop's headphone jack.
Many other people sell this product including Monoprice, Radio Shack, Best Buy
arnyk is offline
post #3 of 10 Old 01-10-2013, 09:59 AM
miatame's Avatar
The Rotel is a terrific amp. Using a headphone out to RCA cable is going to destroy any idea of good sound quality.
You're going to want to invest in a USB digital out adapter, and then get a digital preamp/processor before sending the analog signal on to that Rotel. It should sound amazing.
miatame is offline
post #4 of 10 Old 01-10-2013, 10:07 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I agree that Rotel amps can sound very good indeed.
I don't know about the idea of good sound because that is in people's heads and I can't read minds. ;-)
But I can tell you about what happens to the signal technically.
The performance of audio interfaces in modern computers including laptops are roughly the same as that of a very good CD player.
This is typical:
http://www.ixbt.com/mainboard/intel/dp55wg/rmaa-96.shtml
Frequency response (40 Hz - 15 kHz), dB
+0.02, -0.12
Noise level, dB (A)
-90.4
Dynamic range, dB (A)
90.4
THD,%
0.0022
THD + Noise, dB (A)
-83.4
IMD + Noise,%
0.0083
Crosstalk, dB
-85.3
IMD at 10 kHz,%
0.0087
Bottom line, the OP's laptop might perform worse, but an investment of about $5 in a cable seems like a reasonable risk.
I don't see any purpose in necessarily prejudicing a person against the equipment that they already own. ;-)
arnyk is offline
post #5 of 10 Old 01-11-2013, 05:10 AM - Thread Starter
rocky1's Avatar
thanks everyone.I believe i have some of those cables laying around some where.Will probably give it a try.Its going to be for outside use for now anyways.wont hurt to try.
rocky1 is offline
post #6 of 10 Old 01-12-2013, 08:16 PM - Thread Starter
rocky1's Avatar
well i tryed and did not work for whatever reason.I know the jack works as i tryed some earbuds to make sure. but the outdoor speakers connected to amp to computer did not.Have to trouble shoot when i have time.Didnt even get a hiss.
rocky1 is offline
post #7 of 10 Old 01-14-2013, 11:19 AM - Thread Starter
rocky1's Avatar
Can anyone help me out.This is not working.I connected the cable properly fom headphone jack but i get nothing.Could use the help.Its not the speakers as i tried another set just to make sure.Help pleasePlease
rocky1 is offline
post #8 of 10 Old 01-14-2013, 12:13 PM - Thread Starter
rocky1's Avatar
disregard something wrong with amp.Hopefully just a fuse even though power light is on.Connected to my marantz front aux to try and it worked.
rocky1 is offline
post #9 of 10 Old 01-14-2013, 01:05 PM
Glen B's Avatar
Try the Audioquest Dragonfly USB DAC, or go wireless with the Outlaw Audio OAW3 wireless audio system. Both products bypass the internal soundcard in your laptop, to provide superior sound. I currently use the OAW3 to playback digital music from one of my laptops to my secondary 2-channel system, and it delivery excellent sound quality without any form of external interference whatsoever.
Outlaw Audio OAW3 Wireless System
Glen B is offline
post #10 of 10 Old 01-14-2013, 01:11 PM
miatame's Avatar
I guess I saw Rotel and assumed the OP was going for High Res audio, or at least high quality, but rereading the post I was mistaken. In college I hooked up my laptop through the headphone out to my roomate's mid-fi stereo and it sounded great for parties. If you just want decent to good sound this method is perfectly fine.
If however you are trying to create a high-end solid state music server you'll want to invest in an external DAC and preamp.
miatame is offline
Reply 2-Channel Audio
