What was everyones first turntable when starting out into Audio? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 78 Old 05-30-2014, 06:56 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
Originally Posted by ohYew812 View Post
Bro... you should definitely revisit your old vinyl!
The ol' pops and crackles just add to the memories.
You can get replacement cartridges --> HERE and also HERE
Stylus are available as well, but since it's that old, and for around $30, may as well just replace the cartridge and stylus.
I can't understand why anybody would like listening to the crackles and pops. That said, if the record is in good condition, vinyl does sound very nice.
hogger129 is offline
post #62 of 78 Old 05-30-2014, 07:12 AM
ohYew812's Avatar
Liked: 48
W
It really isn't a matter of 'liking' them, that's how it was then. I guess it's a matter of how old one is. :)
Even the cleanest, most pristine vinyl will have some. But the analog sound is unmistakeable.
ohYew812 is offline
post #63 of 78 Old 05-30-2014, 05:52 PM
Stanton's Avatar
Quoted: 1411 Post(s)
Liked: 741
I've basically only had 2 TT in my life: a Technics 1200 (bought in the 1970's) which was replaced by a Bang & Olufsen TX2 (in the 1980's). The real epiphany came when I upgraded the Technics cartridge to a Grado G1+!! I'm on my second MMC-3 cartridge (B&O), but I figure I'll need to replace the belt eventually.
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #64 of 78 Old 05-31-2014, 07:42 AM
oneinthepipe's Avatar
Location: On the bank of the Charles River, Watertown, MA
My first table was an AR EB-101 that I purchased from George Merrill when he owned a small shop, Underground Sound, in Memphis. It is my only table, and i still play it weekly. It has a new motor and has new belts. I am still using the Audio Technics AT30 moving coil cartridge that my Dad, also in the business, gave me. RIP Dad.
oneinthepipe is offline
post #65 of 78 Old 09-09-2014, 06:42 PM
izombie73's Avatar
Liked: 0
My first memories where spinning vinyl on my Dad's Marantz through McIntosh amps. Nice setup.
Later when I was old enough for my own system it was a Kenwood all in one. You guy's probably remember them, it looked like a stack system that was about 3.5 feet tall. It had dual deck tapes, AM FM tuner, record player on the top and a space on the bottom to put all the vinyl you convinced your mom to get you at the local grocery store Albertsons :-) Yea that's right, I got my first copy of Def Leppard and Motley Cru records from the grocery store along with all the Conan the Barbarian comics.
Times changed and vinyl left my life for awhile but made its way back.
For a bit I had a cheap Sony USB table, then a Project RPM (very cool looking) and finally a VPI Scout. If I had the choice to go back, I'd skip the Sony and Project and go straight for the VPI.
Just my take...
izombie73 is offline
post #66 of 78 Old 09-16-2014, 02:48 AM
rongon's Avatar
Re: crackles and pops...
I found something out about vinyl playback, through reading and experience building my own RIAA eq amp (phono preamp).
The ticks and clicks on a record can produce levels +20dB above the musical peaks in the program material. How a phono preamp deals with this is crucial. If the phono preamp overloads, and it has a time-constant from RC couplings, the circuit can suffer 'blocking.' Basically, if the circuit overloads, it charges the capacitor(s) in the RC coupling(s). The RC time constant might be on the order of 200 milliseconds, but the cap might take several times that to discharge. While the capacitor is discharging, no signal can pass through the amp. What this does is to exaggerate the clicks and pops from the record, and make them very, very annoying.
If you make a phono preamp that has lots and lots of headroom, and is very stable (feedback loops don't go crazy during short overloads), then the clicks and pops are not nearly as aggravating. I took a pretty standard phono preamp and with the help of some knowledgeable guys on the innerwebs, altered the circuit to give it much more headroom, so that the individual stages could never be overloaded by the output from a phono cartridge. The result? Ticks and clicks are barely noticeable. They just don't get in the way of the music, unless the record is really trashed.
Anyway, that helped me see how the observed behavior of an apparently properly working circuit could result in subjectively unpleasant results. This stuff is more complicated than it at first appears.
________________
My first turntable was a Dual sumthin-or-other that chewed up every record it played. It was terrible. It was about 1975, and I thought a German-made turntable would be better than a Japanese-made one. Man was I wrong about that! Before that I had a GE Wildcat
My brother bought a Technics belt-drive with an S-shaped arm (with a Marantz integrated amp and Dynaco A25 speakers). That was a great starter setup for the time.
Hopelessly addicted to this stuff.
rongon is offline
post #67 of 78 Old 09-16-2014, 06:13 AM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
Wow shes got all 4 speeds I see!!
Good for you buddy
Dude111 is offline
post #68 of 78 Old 09-16-2014, 11:23 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
What was the schematic and how did you mod it?
I've known about this for a long time as my fave cart (Garrott Decca) has more output than anything I've ever seen.
A9X-308 is offline
post #69 of 78 Old 09-17-2014, 07:36 AM
Liked: 0
my dad bought me home a Philips suite case record player with 3 albums gen live,Jimmy Hendrix and the Beatles. late 60's early 70's and i was hooked
Trevor58 is offline
post #70 of 78 Old 09-17-2014, 10:24 AM
rongon's Avatar
I read about this in Morgan Jones' "Building Valve Amplifiers", in the section where he goes through designing a phono preamp. It's a great explanation. I don't remember the exact numbers, but the gist of it was something like this:
It wasn't a matter of adjusting for an unusually high output cartridge. If you take a 'normal' MM cart with nominal 5mV rms output (5cm/second), the cartridge can output program peaks that are maybe 20dB higher than that (in voltage terms). That's a 10X increase in voltage output when the cartridge tries to play back a big pop, so 50mV rms output to the first stage, or about 70mV peak.
Since the first stage in my preamp has gain of about 35X, that's 2.4V peak out of the first stage. The 75uS passive filter decreases that by -10dB, cutting the voltage by 1/3 to about 800mV peak. That's 800mV to the second stage, which amplifies by 13X, then is decreased by -10dB by the second half of the passive RIAA filter, so that means a possible max peak voltage of 3.5V out to the third stage! That can hammer the third stage and cause it to block. The grid to cathode bias (or gate to source if talking about an FET) has to be at least -4V in order to allow for that, or that last stage will overload.
So I re-designed the last stage to have a bias of -4V, so that it can't overload on 3.5V peak signal at its grid (or gate, if it was an FET).
I've seen lots of phono preamps where the second stage has a bias of -1V or even lower. That almost guarantees overloads on big clicks or pops.
I don't have the schematic available, but I can post it later if you want. It's not any kind of a perfect design, just a hobbyist's effort.
rongon is offline
post #71 of 78 Old 09-17-2014, 03:27 PM
A9X-308's Avatar
Liked: 951
^^ I have VA and BVA. Thanks.
A9X-308 is offline
post #72 of 78 Old 09-17-2014, 04:24 PM
ti-triodes's Avatar
Quoted: 231 Post(s)
Liked: 260
A Garrard rumblemaster which didn't last too long. OTOH, that was about 10 TT's ago.
ti-triodes is offline
post #73 of 78 Old 09-17-2014, 09:54 PM
audioguy's Avatar
Quoted: 1913 Post(s)
Liked: 1239
Dual 1019
I no longer own this.
audioguy is offline
post #74 of 78 Old 09-17-2014, 10:21 PM
Hbcueducated's Avatar
Quoted: 31 Post(s)
Liked: 961
Mine was a BSR, maybe a 2260. It allowed you to stack multiple records for extended listening pleasure. I cringe at the thought of that now, but I didn't know any better back then. I went from that to a Garrad, which wasn't bad, then to a Technics D202, which I still have and has been trouble free and sounds pretty darn good for a turntable that's over 30 years old.
Hbcueducated is offline
post #75 of 78 Old 09-26-2014, 10:03 PM
Liked: 4
I tried buying a Technics SL-1300 with an Audio Technica cartridge. The dealer installed the cartridge in my new TT. Got it home and it had wow and flutter that wouldn't stop. Ended up being offered a Yamaha YP-D6 and a Shure V15 Type III that worked flawlessly.
That was in 1978.
Sprags is offline
post #76 of 78 Old 09-28-2014, 08:26 PM
Liked: 4
Originally Posted by SMHarman View Post
Quote:Originally Posted by JD NC
1978 Fisher Price Record Player #825
What is that fancy thing?
Now I see this I am pretty sure my first was one of these.  It is about the same age as me!
Those psychedelic looking records must be Hendrix, the Stones and Beatles.
Sprags is offline
post #77 of 78 Old 09-29-2014, 05:35 PM
Bruce Embry's Avatar
Quoted: 13 Post(s)
Hi All,
My first turntable was Dual 1211 that came on a Sony 610A Music System. I used that from 1973 till Dec 1977. In Dec. 1977, I purchase my Dual 1245 with Shure V15-III cartage. I am still using the same turntable today and now it has a Denon DL-304 moving coil cartage.
Bruce.in.Triangle NC
Firewire is alive and kicking!
Bruce Embry is offline
post #78 of 78 Old 09-29-2014, 09:10 PM
Dude111's Avatar
Quoted: 309 Post(s)
Liked: 518
I think I had that player also when I was little buddy! (I had several records)
Dude111 is offline
Reply 2-Channel Audio
