Headphone amp recommendations. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-16-2013, 04:38 PM - Thread Starter
lundrog's Avatar
I ordered a pair of Polk UltraFocus 8000 Active Noise Canceling Headphones. http://www.polkaudio.com/products/ultrafocus8000 I want to match a headphone amp with them, so I get optimal sound when gaming. I play games like battle field 3, etc.
I have a asrock extreme 4 motherboard. http://www.asrock.com/mb/Intel/Z77%20Extreme4/?cat=Specifications
When watching bluray I use a marantz sr7002, I assume that with work fine? It's on the otherside of the room, about 25 feet.
Thoughts?
Roger Lund
lundrog is offline
post #2 of 4 Old 01-19-2013, 10:10 AM
commsysman's Avatar
Quoted: 984 Post(s)
Liked: 526
The receiver seems to have a headphone jack on the front panel.
I am sure you will need an extension cable.
The standard jack on receivers is a 1/4-inch headphone jack, and your headphones have a smaller 2.5/3.5 mm plug, so that will require an adapter.
commsysman is offline
post #3 of 4 Old 01-23-2013, 09:50 PM
ScaryFatKidGT's Avatar
Wait what I'm confused, your receiver should be plenty powerful and I doubt an amp would do anything at all for those headphones.
ScaryFatKidGT is offline
post #4 of 4 Old 01-23-2013, 09:50 PM
Reply 2-Channel Audio
