Budget simple receiver reccomendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2013, 11:02 PM - Thread Starter
davidcsally's Avatar
Hello all,
I hope I'm posting this in the right place. I'm looking to buy a stereo reciever, but I have no idea what to get.
A couple years ago my dad gave me his vintage receiver - an old 4-channel Sansui QR-1500. The thing is wood grain and looks like its from the '70s. I immediately bought some big, cheap floorstanders - some Sony ssf-7000s. It sounds great to me and I've been really happy with it, but I really want to swap it out for a modern receiver with a remote and a simple way to hook up a TV and computer. I'm assuming either HDMI or some kind of digital / optical connection is what I'm looking for. All I really want it to do is control the speakers. My budget is less than $300. The speakers will be used primarily for watching movies and TV.
The Sony's: http://www.amazon.com/Sony-SSF-7000-Floor-Standing-Speaker-Woofer/dp/B000OG4E2U
davidcsally is offline
post #2 of 5 Old 01-18-2013, 06:16 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by davidcsally View Post
Hello all,
The standard advice is that your best bet for setting up a 2.0 or 2.1 system is a 5.1 AVR. You just bring up its configuration menu, tell it what speakers are hooked up and what speakers aren't available, and it does the rest.
You can easily obtain a good 5.1 AVR in your price range. The primary manufacturers are Denon, Onkyo, Pioneer, and Yamaha. The model numbers are pretty fluid, so check around and see what's available today.
arnyk is offline
post #3 of 5 Old 01-18-2013, 06:31 AM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
Bond 007 is offline
post #4 of 5 Old 01-18-2013, 04:30 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You can get the Onkyo TX-NR414 for $230.
That is a very nice receiver for the money, with lots of connectivity and features, and will work fine with your speakers.
commsysman is offline
post #5 of 5 Old 01-23-2013, 09:59 PM
ScaryFatKidGT's Avatar
ScaryFatKidGT is offline
Reply 2-Channel Audio
