does 2 channel mean no amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-18-2013, 09:53 AM - Thread Starter
svt2nv's Avatar
i was looking at super cheap sound bars and can't really tell if they're amplified. the cheapest one i found is this lg 2020a, it says it's a 2 channel but i don't know if it's powered.
http://www.lg.com/us/home-theater-systems/lg-NB2020A
svt2nv is offline
post #2 of 17 Old 01-18-2013, 10:04 AM
Selden Ball's Avatar
Quoted: 3074 Post(s)
Liked: 1503
It says "40W Total Power". That means it includes an amplifier.
Selden
Selden Ball is online now
post #3 of 17 Old 01-18-2013, 10:17 AM - Thread Starter
svt2nv's Avatar
wicked thanks.
svt2nv is offline
post #4 of 17 Old 01-18-2013, 10:50 AM
Liked: 1503
You're very welcome.
Selden
post #5 of 17 Old 01-18-2013, 11:06 AM
SAM64's Avatar
Liked: 78
How do you think they work?
SAM64 is offline
post #6 of 17 Old 01-18-2013, 11:28 AM - Thread Starter
svt2nv's Avatar
You've never seen speakers without built in amps before?
svt2nv is offline
post #7 of 17 Old 01-18-2013, 11:37 AM
SAM64's Avatar
Liked: 78
Of course...why ask that?
how do you think speakers are driven...magic?
SAM64 is offline
post #8 of 17 Old 01-18-2013, 11:39 AM
Liked: 1503
There is a wide variety of devices sold as soundbars.
Some have HDMI connections and internal amps.
Some have line-level analog connections and internal amps.
Some have speaker connections and no internal amps -- so you need a separate receiver for them.
And some have absurdly high prices for little content.
In other words, you have to shop carefully to get the type you need.
Note that soundbars with larger speakers usually will provide better sound than the ones with tiny speakers, but they'll also tend to cost more. Some have external "subwoofers" to improve the sound. I put the word "subwoofer" in quotes because they usually are nothing of the kind. They're frequently just separate woofers used to fill in the upper bass that the tiny speakers in the soundbar itself can't provide. Subwoofers typically have speakers larger than 8" in diameter plus their own builtin amplifier.
Selden
post #9 of 17 Old 01-18-2013, 11:46 AM - Thread Starter
svt2nv's Avatar
svt2nv is offline
post #10 of 17 Old 01-18-2013, 01:16 PM
SAM64's Avatar
Liked: 78
SAM64 is offline
post #11 of 17 Old 01-18-2013, 08:43 PM - Thread Starter
svt2nv's Avatar
svt2nv is offline
post #12 of 17 Old 01-19-2013, 08:23 AM
SAM64's Avatar
Liked: 78
lol
SAM64 is offline
post #13 of 17 Old 01-22-2013, 01:25 PM
K Shep's Avatar
2 channel means 2 speakers. As opposed to 5.1 which is 5 speakers, .1 = one subwoofer.
K Shep is offline
post #14 of 17 Old 01-22-2013, 05:56 PM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Some sound bars have amplifiers and some don't; most do, but you can't assume it.
Read the detailed specs.
commsysman is offline
post #15 of 17 Old 01-23-2013, 01:17 AM - Thread Starter
svt2nv's Avatar
thanks guys. i ended up picking up a cheapo insignia bar for 80 new, it did the trick for my tv stereo.
svt2nv is offline
post #16 of 17 Old 01-23-2013, 02:02 PM
vipin62's Avatar
I read the spec on the lg soundbar that you asked about. If good sound is what you're after, what does 10% THD mean when it comes to sound quality?
vipin62 is offline
post #17 of 17 Old 01-25-2013, 09:28 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
It means that dialog will probably sound like someone speaking with tin foil over their mouth. LOL
It says the output is 20w x 2 at 10% THD, so I'm guessing that 5 to 8 watts is all these are good for when it comes to clean audio.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Reply 2-Channel Audio
