3.5mm to digital - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-18-2013, 04:36 PM - Thread Starter
Viper5's Avatar
I got a new tv today (55lm6200) and it only has one fixed audio out port which is digital. My previous tv had a digital, 3.5mm and rca fixed out signal to which I could connect my headphones. The headphones come with the 3.5mm male to male (one end into base unit the other into tv). It also comes with a female 3.5mm to rca (red/white). So basically on my last tv I was using 3.5mm (base) to rca (tv) and now my tv only has a digital optical audio out for a fixed audio. Can I get an adapter or something or does this tv render my headphones useless for tv connection
Viper5 is offline
post #2 of 3 Old 01-19-2013, 09:04 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
You need to get a digital-to-analog converter, like for example the AGPtek that Amazon is selling for $20.
Then you need a headphone amplifier, which can cost from $30 to $1000.
commsysman is offline
post #3 of 3 Old 01-19-2013, 10:25 AM
whoaru99's Avatar
Liked: 69
You can probably go to a local pawn shop or on Craigslist, et al, and find an older used AV receiver with toslink input and headphone jack for less than a converter and separate amp.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Reply 2-Channel Audio
