2.0/2.1 setup for a small apartment living room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-21-2013, 03:40 PM - Thread Starter
cupcake jesus's Avatar
Everyone,
I'm a total newbie (have only owned HTIB setups before), and have a small apartment living room where running cable for a 5.1 or a 7.1 setup would be a big issue. I'd like to upgrade from TV speakers to a 2.0 or a 2.1 system that will be used both for listening to CD's and watching movies.
I tracked down an inexpensive pair of Mirage OM-9's that I'll be buying if they're in good working order. I'm thinking that I should buy a 5.1 or 7.1 receiver so that I'm future-proof, and can upgrade to more speakers when I buy my own house and can run cable through the walls. Is this a good idea? Can a 5.1 or 7.1 receiver handle a 2.0/2.1 setup? Would a lower-end Yamaha or Onkyo receiver be a good receiver for this setup? What should I look for in a subwoofer?
Like I said, I'm a newbie. Thanks everyone for their help!
cupcake jesus is offline
post #2 of 7 Old 01-22-2013, 12:20 AM
Knucklehead90's Avatar
Quoted: 411 Post(s)
Liked: 340
For an apartment you may not need a sub with those OM-9s - frequency response is down to 38hz. Nice speakers and a great start to a nice sounding setup. A decent AVR should work just fine.
What is your budget for an AVR?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 7 Old 01-23-2013, 07:29 PM - Thread Starter
Thanks for the help! I'm looking to spend no more than $400-$500 for a receiver. What would you recommend?
post #4 of 7 Old 01-23-2013, 09:39 PM
postrokfan's Avatar
Quoted: 533 Post(s)
Liked: 3174
The Denon 1713 can be had for $449. It comes with Audyssey MultEQ XT.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #5 of 7 Old 01-23-2013, 10:17 PM
ScaryFatKidGT's Avatar
Go 3.0/3.1 if you are accustom to having surround sound and watching movies, the center channel will help a lot and give the vocals better clarity, then you can eventually get some wireless surround speakers or adapters.
Hands down I would go with the Pioneer 1022-k because amazon has (and Bestbuy DID but should match) it for $250 and its a $450 receiver. A rear receiver can run 2.0, 2.1, 3.0, 3.1, 5.0, 5.1 pretty much every thing.
http://www.amazon.com/Pioneer-VSX-1022-K-7-Channel-Receiver-Network/dp/B007O5ATC8/ref=sr_1_1?ie=UTF8&qid=1359003435&sr=8-1&keywords=pioneer+vsx-1022-k
How much are you going to spend on speakers? The Pioneer FS52's and matching center are always good for cheap.
ScaryFatKidGT is offline
post #6 of 7 Old 01-26-2013, 08:54 AM - Thread Starter
Guys,
I picked up the Mirage OM-9s today. The seller and I spent about 45 minutes with different CDs and movies (I brought the Avengers Blu-Ray, The Joshua Tree MFSL edition CD, and Led Zepplin 4 with me), and they sounded great. It was a no-brainer for $200.
I think that they have enough bass for my apartment, but I see what you mean about a center channel. I'm going to get a receiver next, then get a center channel a little bit later.
I'm thinking about picking up that Pioneer receiver. Will Best Buy match an online price, or should I just pick it up from Amazon?
post #7 of 7 Old 01-26-2013, 10:16 AM - Thread Starter
I just pulled the trigger on the Pioneer 1022-K from Amazon. Can't wait to hook it all up next week!
Reply 2-Channel Audio
