Peachtree Nova (80) - Can it properly power a pair of Snell E.5 Floorstanders? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-22-2013, 10:33 AM - Thread Starter
miatame's Avatar
Looking to simplify...or upgrade...or change, whatever you want to call it. Using a 5 disc Denon player digitally to a Lexicon DC-1 and Rotel 971 (60 wpc).
The DAC in the Denon is probably worth bypassing and I've heard amazing things about the NOVA. I have no doubts the newer NOVA 125 can power it but the Class D amp scares me. I want warm...borderline dark sound and the Snells are sensative to sources.
So the NOVA is rated as 80 wpc into 6 ohm (come on...just rate it to 8 like most others). The Snell E.5 floor standers are factory described as 90 db and nominal 4 ohms. Assuming the NOVA is happy at 4 ohms all day that sounds like an easy load, right?
-Jeff
miatame is offline
Reply 2-Channel Audio
