Bookshelf speakers and small amp recommendations - AVS Forum | Home Theater Discussions And Reviews
Old 01-22-2013, 02:18 PM - Thread Starter
hg1027's Avatar
Hey all
I posted a long rambling question (seen here) and got no responses, probably due to it being a massive wall of text.
So, cliffs of that:
I need a pair of speakers and an amp, or a pair of powered speakers, that I can take with me as I expat my way around the world. Amp and passive, or active, no real preference. As to size, I need it all to fit in a large suitcase, so the towers and AVR I have are not going to work. Bookshelf or smaller. Company insures everything, so I'm not too worried about it getting damaged on the plane. Must work with 120-240v, 50-60hz.
Will be used in hotels, apartments, and rent houses depending on where they put me and when they move me. I understand I'm not going to get house shaking bass, but I want to do better than tv/laptop speakers.
Budget of $200 for small actives, $400 for 5 inch+ and separate amp.
Gogogogogogo
hg1027 is offline
Old 01-22-2013, 02:34 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by hg1027 View Post
Hey all
So, cliffs of that:
Gogogogogogo
Dimensions and allowable weight of that "large suitcase" ?
arnyk is offline
Old 01-22-2013, 02:47 PM - Thread Starter
hg1027's Avatar
I'm looking at the dimensions of the A5+ or MTX 5i for speaker size, coming to about 11x7x9. Pair of A5+ is about 25lbs, Rokits would be 30lb for a pair. I think that's about as heavy and big as I want to deal with.
I've been looking at the small Class T amps (see this Topping) to go with something like these MTX Monitor 5i if I feel cheap, or these JBL Control-1 Pros if I hear they are good. That brings the total cost down to about $275, which I would be perfectly comfortable with if it's a decent setup.
hg1027 is offline
Old 01-22-2013, 07:20 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
fwiw, dayton audio dta-100 tri path amp $90 ( parts express)and a pair of cambridge audio s-30 speakers $220 ( audio advisor). 2 of my favorite "small" great sounding audio components
i'm so laid back,i'm laid out
smasher50 is offline
Old 01-22-2013, 07:30 PM - Thread Starter
hg1027's Avatar
Thanks very much for the recommendation. I'll investigate.
hg1027 is offline
Old 01-22-2013, 07:44 PM
citizen arcane's Avatar
Quoted: 284 Post(s)
Liked: 8319
While not owning a pair, the S30s would be on my very short list for affordable book shelf speakers. Go here for further reading http://www.avsforum.com/t/1327952/almost-got-floored-by-cambridge-s30. Cambridge also offers the smaller S20s if size is a further consideration.
Further info from Audio Advisor-
S30 http://www.audioadvisor.com/prodinfo.asp?number=CAS30
S20 http://www.audioadvisor.com/prodinfo.asp?number=CAS20
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
Old 01-22-2013, 08:03 PM - Thread Starter
hg1027's Avatar
I read that thread, and several other reviews. Sounds good.
Regarding the amp, I'll primarily be feeding this from a desktop or a laptop. Would the USB on the topping tp30 be enough of an improvement over the Dayton to recommend it?
Thanks for any help.
Edit: I guess a better question might be, Would some sort of DAC, whether integrated as in the Topping models or discrete (make recommendation here) be an improvement over running line out from a computer?
hg1027 is offline
Old 01-23-2013, 08:52 PM
ScaryFatKidGT's Avatar
KRK rokit 5 or 6's. Or any pair of book shelves with the Wharfedale diamond 10.1's and Screw a lepai amp to the top of one of them?
ScaryFatKidGT is offline
Old 01-25-2013, 06:20 PM
Liquid360's Avatar
The new DefTech SM45-65s are awesome and would suit your need nicely.
Liquid360 is offline
Old 01-25-2013, 08:38 PM - Thread Starter
hg1027's Avatar
It looks like the DefTechs would be significantly more expensive than I was looking for. Thanks for the suggestion though.
hg1027 is offline
Old 01-25-2013, 09:41 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Newegg have the DefTech SM350 for $180 a pair and the SM450 for $280 a pair. Not a whole lot of difference between them and the new SM45/55 sonically. An Emotiva mini-X a-100 would probably be sufficient to drive them. The SM350 and mini-X would be $400 total and would be better than the Audioengine A2 and possibly the A5+. The Dayton Audio APA150 would probably work as well but would be larger in size. The same $400 would get you either the Audioengine A5+ or the Emotiva Airmotiv 5's powered monitors which, to me, sound better than the A5+.
Only reason I wouldn't touch any of the Topping stuff is because USB Audio is only 16/48. Something like the Audioengine D1 would be better at USB Audio.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Old 01-25-2013, 09:50 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Your option/choice >
However I prefer the Cambridge S30 over the Definitive SM350, for music.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 01-28-2013, 08:54 AM - Thread Starter
hg1027's Avatar
Any opinion on the Infinity Primus series vs the Cambridge S30s? I understand the front port on the Infinity allows it to be placed closer to the wall, but I've also read several people suggest jamming a sock in a rear port and putting it where you want.
hg1027 is offline
Old 01-28-2013, 11:30 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The Cambridge tiny 4.5" woofer can't hold a candle, bass wise to the 6.5" in the P163:
Freq,Hz Max SPL, DB
10 61
20 73
30 80
40 85
50 89
60 92
70 95
80 97
90 99
100 101
110 102
120 104
130 105
140 107
150 108
160 109
170 110
P163 6.5 inch
Freq,Hz Max SPL, DB
10 67
20 79
30 86
40 91
50 95
60 98
70 101
80 103
90 105
100 107
110 109
120 110
130 112
140 113
150 114
160 115
170 116
All other parameters but woofer size held equal...
The Primus 6.5 inch woofer is still not too large to match up well with the dome tweeter.
arnyk is offline
Old 01-28-2013, 11:54 AM - Thread Starter
hg1027's Avatar
The 153 is on sale at my local Frys for $50, so I'd be looking at that one. I've actually already bought it to pick up after work, and I'll try to listen to them before I walk out with them. The larger woofer and the front port, as well as the decent reviews on this site caught my eye, and the discount pushed them over the edge. The only problem might be the size, they are significantly bigger than the S30s, so I have to decide if I'm willing to haul them around.
I'm also ordering both the dayton DTA100a and the APA150 to see if the power of the 150 is worth the size and weight.
I'll have plenty of time to return and reorder if you guys tell me I'm doing it wrong.
hg1027 is offline
Old 01-28-2013, 02:34 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Chances the demo at Frys will tell you nothing to how these will sound in the future.
arnyk is offline
Old 01-28-2013, 03:22 PM - Thread Starter
hg1027's Avatar
Well if the Infinitys don't sound good (not that I have a great ear, and now that I'll have a mostly empty, echoey house to listen to them in...) I can always still go for the S30s. We'll see.
hg1027 is offline
Old 01-28-2013, 04:46 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
Freq,Hz Max SPL, DB
10 61
20 73
30 80
40 85
50 89
60 92
70 95
80 97
90 99
100 101
110 102
120 104
130 105
140 107
150 108
160 109
170 110
P163 6.5 inch
Freq,Hz Max SPL, DB
10 67
20 79
30 86
40 91
50 95
60 98
70 101
80 103
90 105
100 107
110 109
120 110
130 112
140 113
150 114
160 115
170 116
the infinity' are in much larger cabinets 15x11x8 and weigh 16#
the cambridge s-30's 9x8x6.3 and weigh 6.6# for their size they can put some nice bass out and honestly what would you rather lug around through the airport
Old 09-23-2015, 07:43 PM - Thread Starter
hg1027's Avatar
Since it looks like people still look at this thread (I see the viewed count go up when I poke around my old posts every few months) I'll give a quick update.
I ended up with the primus 143 and the dta100, and I've been very happy with them moving around. We lived in a hotel in Morocco for 6 weeks, and I hooked these up to the TV and my raspberry pi on the second day. We moved to a condo for a year, where they went in the dining room/kitchen, then to a hotel in Spain for 6 months, then a rent house back home, and now I'm in my own new house, they're in the kids den for Doc McStuffins and dance parties. I get to listen to podcasts while I work out in there in the evenings.
I made a plywood case that held the speakers, amp, and a bunch of cables, and made it much easier to haul it all around. No pics handy, but that made all the difference. It was heavy, but I could carry the whole mess in one hand, and easily drag them to a party or the next house.
The amp got a loose rca connection early on, but I soldered it back in, and no further trouble. The speaker cases are quite sturdy.
hg1027 is offline
