Outlaw RR2150 - the missing link... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-25-2013, 09:50 PM - Thread Starter
keleven's Avatar
OK, so my main stereo system is a Peachtree Nova fed by a Sonos by optical link and a Synology NAS drive by USB link (for occasional playing of 24/96 files which Sonos doesn't support). Just moved into a bigger house and want to set up some additional Sonos zones with less expensive setups.
I have my eye on the Outlaw RR2150, which looks like a beautiful piece of equipment. But its only digital input is USB, while the Sonos boxes can only output digitally via optical or coax. I would have thought it would be a simple matter to find a converter with an optical or coax input and a USB output - but apparently not. Can't find a single one, although googling does reveal a few other examples of people asking exactly this question and coming up dry.
So, any ideas? Does this kind of converter actually exist?
If I can't figure out a way around this I'll probably go for the HK3490 instead. I don't like the idea of using the analog outs on the Sonos.
Thanks in advance...
keleven is offline
post #2 of 8 Old 01-25-2013, 10:06 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Google: "usb-spdif converter"cool.gif
jdcrox is offline
post #3 of 8 Old 01-26-2013, 02:59 PM - Thread Starter
keleven's Avatar
Thanks but isn't that the opposite converter? i.e. takes a USB stream and turns it into coax or optical, rather than the other way around?
keleven is offline
post #4 of 8 Old 01-26-2013, 10:52 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Looks like you are right. Have you tried in the Outlaw forum? They might have some ideas.
jdcrox is offline
post #5 of 8 Old 01-27-2013, 09:43 PM - Thread Starter
keleven's Avatar
Didn't realize there was one, but thanks for the tip!
keleven is offline
post #6 of 8 Old 01-28-2013, 09:03 PM
postrokfan's Avatar
Quoted: 524 Post(s)
Liked: 3136
The nice thing about the RR2150 is that it provides bass management. On the other hand, the 3490 will do exactly what you want with no need for a converter and it's cheaper. You could also do what you want with an AVR.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #7 of 8 Old 01-29-2013, 07:57 PM
BenWaB3's Avatar
I had one of these units a few years ago for a trial run. It is a very good sounding piece. One thing about it though -at least then, they may have changed it by now - was that there was a big volume drop going from the analog inputs to the usb one I don't know if that would present a problem for you or not. I sent it back because I had the chance to get a Luxman R-1070 at the same time. Through the headphones the Outlaw was a little cleaner & crisper but through speakers the Luxman slightly edged it out. The Outlaw is a fine sounding piece though & better perched to fit in the modern age than the all old-school analog of the Luxman.
BenWaB3 is offline
post #8 of 8 Old 01-31-2013, 06:36 PM
michaelkingdom's Avatar
Quoted: 46 Post(s)
Liked: 26
The RR2150 is an excellent piece. I run USB audio out of my computer to it and the DAC is VERY good. The Sonos internal dac is also very good. I would just run rca out of the sonos - which I do - directly to the Outlaw. Also, I run the sonos digital toslink (which plays concurrently with the Sonos analog out) to a Behringer DEQ2496 which I use as another dac to manipulate the sound and then analog from that to the RR2150.
michaelkingdom is offline
Reply 2-Channel Audio
