Setting/Adjustment Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-03-2013, 01:22 PM - Thread Starter
Torcha's Avatar
I'm pretty new to starting my gear collection, and I am saving up for the rest later.. I currently have a 2.0 which consists of a Marantz SR5007 and a pair of B&W CM5s.
My questions are this:
1.) At what decibel do you consider a somewhat loud decibel on your avr/pre? Granted in my situation the setup is in my rather small room, roughly 10x15, and it's less than ideal. On my Marantz I generally listen to movies/music/gaming anywhere from -45.0dB to -35.0dB. I was just wondering what everyone else generally set their dB at for general listening. I've always been nervous to let loose, for fear of messing up my speakers haha.
2.) I've ran my Audyssey, and I'm just curious what EQ setting to set it to. Virtual usually sounds to the loudest and fullest. Or i can do: Stereo / Auto / Multi Channel In. What's correct?
Any help is appreciated.
Torcha is offline
post #2 of 8 Old 02-03-2013, 01:33 PM
glangford's Avatar
Quoted: 298 Post(s)
Liked: 233
If you are running stereo, use stereo.
Loudness is subjective. Don't fry your ears and enjoy.
glangford is offline
post #3 of 8 Old 02-04-2013, 08:27 AM - Thread Starter
Torcha's Avatar
Should I use Stereo for everything? Movies, music, & gaming? And again, I'm always nervous about messing up my speakers, but what dB is considered moderately loud? Once I put it back to stereo I had to go to about -35.0dB to be loud enough for the time being.
Torcha is offline
post #4 of 8 Old 02-04-2013, 08:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Your volume control settings are actually uncalibrated.
You need a SPL meter or something like it for reliable, relevant results.
For your purposes, the cheapest you can find will probably be just fine.
arnyk is offline
post #5 of 8 Old 02-04-2013, 09:04 AM
glangford's Avatar
Quoted: 298 Post(s)
Liked: 233
Use stereo for everything. As far as volume goes if you don't hear any distortion you ate probably ok.
post #6 of 8 Old 03-17-2013, 09:34 AM - Thread Starter
Torcha's Avatar
Another question.. Should I turn Dynamic EQ ON of OFF? I've tried it both ways, and with it off is just sounds really flat. I mostly just connect my laptop via RCA -> headphone jack. I just feel like my sound is lacking a lot. Since I have started using Stereo I still usually listen to music at about -35dB to -30dB. Maybe I just need to turn it up louder? I'm just nervous to crank it and mess something up in the receiver or speakers themselves.
Any suggestions?
Edit: Will a cheap ~$30 SPL meter from amazon work fine?
Torcha is offline
post #7 of 8 Old 03-17-2013, 03:50 PM
glangford's Avatar
Quoted: 298 Post(s)
Liked: 233
Leave dynamic eq on. Dynamic volume off. For movies you may want dynamic volume on. That will help with the dialog in a 2.0 system. I use evening mode for movies.
post #8 of 8 Old 03-17-2013, 03:50 PM
glangford's Avatar
Quoted: 298 Post(s)
Liked: 233
Reply 2-Channel Audio
