Onkyo S3400 HTIB receiver into 2.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-06-2013, 08:28 PM - Thread Starter
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I have a s3400 laying around from when I had no idea that HTIB sucked. Can I somehow use this receiver as a 2.1 just for music? Just get good speakers and a powered sub? How would I do this and add a sub with no pre out? Will the front channels be enough juice?
Thanks in advance.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #2 of 5 Old 02-09-2013, 09:32 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The weakness of smaller receivers is that they don't have big enough power supplies to run 5 speakers well; not enough total current available.
They usually do fine running two speakers; just avoid speakers rated as 4 ohm speakers. 8 ohm speakers will work best.
If there is no preout for the sub, that is not a problem.
Just run a pair of speaker wires from the two speakers to the HIGH-level inputs of the sub; no problem.
What sort of budget do you have for a pair of good speakers?
commsysman is offline
post #3 of 5 Old 02-09-2013, 09:53 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
As far as the power goes, that is unlikely to be a problem. I've read the other post and I've been providing an engineered technical rebuttal for weeks but it clearly goes over some people's heads.
Executive summary - having enough power seems to be the least of your worries.
To me the most relevant question is how will we hook up a decent subwoofer and setup a system with different speakers?
The first problem I see is the lack of a RCA jack marked "LFE" That means that hooking up a proper powered subwoofer takes some fanageling. I can tell you how if you are interested.
The only documentation I can get online is a very fragmentary "Quick setup manual" so anything much else I say would be speculation.
http://filedepot.onkyousa.com/Files/QuickHookup/SN29400594_HT-S3400_QSS_En_web.pdf?CFID=2338480
If there are setup menus that let you make typical adjustments for a good speaker setup, they are hidden from me. If they don't exist, you are pretty much screwed and need to move on.
arnyk is offline
post #4 of 5 Old 02-09-2013, 05:45 PM - Thread Starter
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I have a very expensive denon/deftech system we just installed last year, this is not in the budget and is for the garage anyway. So I'm really looking to get lucky on Craigslist.
In regards to the sub, I looked at the back of both my subs and neither has speaker wire inputs.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #5 of 5 Old 02-10-2013, 10:52 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
It is rather odd to not have speaker-level inputs on a subwoofer.
A Polk PSW505 can be had for around $200, and has both line-level inputs and speaker-level inputs, as well as a gain control and Frequency limit adjustment. This is normal for a subwoofer.
It sounds like your subwoofers do not have the normal configuration, so you may need to upgrade there.
Reply 2-Channel Audio
