HK 3490 or Yamaha R-S500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-09-2013, 07:21 PM - Thread Starter
telemike's Avatar
Looking to get a new stereo receiver to power my vintage Infinity Qb's @ 4 ohms.
I like the looks of the Yamaha, vintage looking. The HK has plenty of power, hut is more futuristic in looks and has way more features than I need.
My main audio source is a CD player.
I am also looking at the Yamaha A-S300 integrated, about same price as receiver but less watts.
The reviews in the HK report very nice power amp section.
telemike is offline
post #2 of 22 Old 02-10-2013, 09:23 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
IMO the Harman-Kardon 3490 is a much better-sounding receiver and would certainly be my choice.
commsysman is offline
post #3 of 22 Old 02-10-2013, 09:28 AM - Thread Starter
telemike's Avatar
Also thinking about the Yamaha A-S300 or 500 integrateds
Sent from my A500 using Tapatalk HD
telemike is offline
post #4 of 22 Old 02-10-2013, 09:32 AM
commsysman's Avatar
Liked: 569
I personally do not like the sound of the Yamaha amplifiers.
The HK is much better-sounding IMO, and the reason is because it has a much larger power supply to give plenty of power and weight to its output.
I especially question whether the Yamaha amplifiers will drive 4 ohm speakers well.
post #5 of 22 Old 02-10-2013, 08:05 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
The Yamaha receivers mentioned are in fact 4-ohm rated. The 300 is rated at 50W per channel and the 500 is rated at 75W per channel into 8 ohms. The choice comes down to what features you desire. The HK 3490 is a bit more powerful (150W at 4 ohms) and has an onboard DAC as well as other extras such as Dolby Virtual Speaker
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #6 of 22 Old 02-11-2013, 03:28 AM
TuenMuner's Avatar
R-S500 also has an on-board DAC. It is the A-S500 that doesn't have one.
I suggest spend a little more for A-S700 or A-S1000(which I own), both of these are going to sound better than R-S500 or the H-K.
BD-A1010/CD-S1000/PF60
HTR-6290/A-S1000/XBR55X900E
NS-555/SOAVO-900C/NS-125F
TuenMuner is offline
post #7 of 22 Old 02-11-2013, 06:57 AM - Thread Starter
telemike's Avatar
My budget is $200-400
Sent from my XT907 using Tapatalk 2
telemike is offline
post #8 of 22 Old 02-11-2013, 07:46 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I like the looks of the Yamaha, vintage looking. The HK has plenty of power, but is more futuristic in looks and has way more features than I need.
Yes, and th A-S300 shows more than average evidence of being a little modern, in that it has bass managment,
You are probably choosing to get far less good sound for the money than you would get from a 5.1 AVR.
The idea that every amplifier sounds different, and that AVRs necessarily sound inferior to separates and integrated amplifiers is an audiophile myth that benefits dealers by putting you on a treadmill.
More of the things that give you a potential for great sound generally cost less in the AVR.
However, if you are bound and determined to obtain the A-S300 then check around and see if you can obtain the more-powerfully A-S500 for a similar price. Technically, they are almost the identical same device except for power output.
arnyk is offline
post #9 of 22 Old 02-11-2013, 07:51 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
If you did a little research,
http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=45663
you'd find that the power ratings of the Yamaha are: 180 WPC @ 4 ohms and 220 WPC @ 2 ohms.
arnyk is offline
post #10 of 22 Old 02-11-2013, 04:34 PM - Thread Starter
telemike's Avatar
The tone controls on the HK, encoders? They sure are small and cheesy.
telemike is offline
post #11 of 22 Old 02-12-2013, 09:10 AM - Thread Starter
telemike's Avatar
Very close to pulling trigger on HK. Love the Yamaha looks but the equivalent model to the HK is the 700 which js $100 more now that HK is discounted.
Really want Onkyo A9050 but out of budget.....
telemike is offline
post #12 of 22 Old 02-12-2013, 02:06 PM
NADz's Avatar
None of the Yamaha equipment you mentioned offers a built in DAC including the R-S500. If they do please point me to the info. smile.gif
NADz is offline
post #13 of 22 Old 02-12-2013, 02:07 PM
NADz's Avatar
NADz is offline
post #14 of 22 Old 02-12-2013, 03:43 PM - Thread Starter
telemike's Avatar
DAC is not important to me. Either Yamaha as500 or hk
telemike is offline
post #15 of 22 Old 02-13-2013, 01:05 PM - Thread Starter
telemike's Avatar
Much as I like the retro looks of Yamaha, the HK price is hard to beat.
telemike is offline
post #16 of 22 Old 02-13-2013, 02:32 PM
RyanA3's Avatar
I have been considering the Onkyo A-9050, Yamaha a-s500, BOTH with great power supplies. I will have to read up on the other suggested in this thread.
You said the A-9050 was out of your price range. Then maybe you could consider the OnkyoA-5VL, it's a bit less. not much though.
good luck
Photo Tour of my home - 2ch, 3.1, & 5.1 builds
But a whole new house is getting wired now!
New media room shaping up: Sony XBR70X850B 4K, Denon AVR-X4100W, Studio 60s
Thanks to all the AVS members. This is a great community.
RyanA3 is offline
post #17 of 22 Old 02-13-2013, 02:38 PM
SimpleTheater's Avatar
Quoted: 205 Post(s)
Liked: 96
Considering that you can get a new Yamaha A500 for about $375 I'd just spend the extra money on that and ignore the 300.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #18 of 22 Old 02-13-2013, 02:50 PM
RyanA3's Avatar
here is a great review of the HK 3490 http://forum.audiogon.com/cgi-bin/fr.pl?ramps&1240627797
RyanA3 is offline
post #19 of 22 Old 02-13-2013, 03:42 PM - Thread Starter
telemike's Avatar
Cheapest i can find the a-s500is $399
telemike is offline
post #20 of 22 Old 02-13-2013, 08:33 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
Is that not within your budget?
post #21 of 22 Old 02-14-2013, 06:22 AM
Quoted: 205 Post(s)
Liked: 96
In general, I have to agree with this statement. The only thing at this price range you should be looking at is power output to insure you can drive your speakers at sufficient levels - especially if you have speakers with low sensitivity. Of course you can't look at the manufacturers specs, and my favorite story is about a Sherwood A/V 7.1 reciever that the company rated at 100 watts channel, but when it was put on the test bench,it put out (and I'm not making this up) 5.2 watts per channel - that's a decimal between the 5 and the 2. SOURCE
I've linked a picture below from Sherwoods website. IMO, you should be looking for a reliable product that can drive your speakers that has the features you want - for example the A/V Yamaha receivers don't have phono inputs, where the integrated amps do. Of course the integrated amps aren't going to be able to play back a blu-ray in 7 channels.
post #22 of 22 Old 02-14-2013, 09:43 AM - Thread Starter
telemike's Avatar
Stereo only system with cd player
telemike is offline
Reply 2-Channel Audio
