Parasound Zdac or Cambridge Audio DAC Magic? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2013, 08:13 PM - Thread Starter
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Any recommendation which DAC I would be better off using? The Zdac is using Analog Devices chip and DAC Magic uses Wolfson chip.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2 of 4 Old 02-24-2013, 08:15 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3076
I have the Zdac and use the optical with an airport express and also the USB connection with my laptop. IMHO it sounds great for the money. On the other hand, the Cambridge can be used as a digital preamp and features more connectivity. I guess your choice would depend on what features you require.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 4 Old 02-24-2013, 08:19 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
I'll only be using it as a DAC for my CD transport and nothing else so in terms of functionality, for my usage, they will be both identical.
my home theatre
post #4 of 4 Old 02-24-2013, 09:05 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3076
In that case I would probably go with the Zdac. Great SQ for the price.
Reply 2-Channel Audio
