Audiophile 2 channel AMP - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2013, 01:39 PM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Looking for so some recommendations for a really decent 2 channel amplifier for playing FLAC files out of an PC.
I have an "High-End" Asus soundcard. http://www.asus.com/Sound_Cards_and_DigitaltoAnalog_Converters/Xonar_Essence_STX/
These are hooked up to Focal Cubs http://www.focal.com/en/20-sib-co
All in a room 12x14. Not interested in upgrading the speakers as there are speakers that I used in my home theater. Also trying to upgrade the soundcard as the sound card was to complement some AudioTech headphones.
Looking to spend about $500.. Would be nice if the AMP had USB DAC integrated.
Before the audiophile heads start in... I don't want real audiophile equipment as it is out of my range. I wont even listen to audiophile equipment because I would go broke trying to get that level of f quality.
avsform1 is offline
Old 02-24-2013, 01:54 PM
K Shep's Avatar
Teac stereo integrated amplifier with built in Usb Dac asynch.
This unit fits your budget and requirements and when I searched for the unit for this post I found that Amazon has a used unit for under $400 if you're interested in purchasing used.
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 95
K Shep is offline
Old 02-24-2013, 02:03 PM
weez82's Avatar
No need to get an external dac as you already have a nice on built into the Asus card. If you're looking to improve your sound you'll need to get better speakers or headphones.
weez82 is offline
Old 03-22-2013, 07:54 PM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
I've came to the that conclusion as well... I have a great pair of Audio Technicas for the headphones. So I've decide on getting a decent set of speakers. I am think on the line of AudioEngine 5+. Any other suggestions for speakers along the same line as the A5+?
avsform1 is offline
Old 03-23-2013, 12:49 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Class A is offline
Old 03-24-2013, 09:57 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest the Audioengine 2 speakers, which I think sound better than the 5. I use them with my PC and love them. You will really need some kind of sub with either of them if you want any decent bass at all.
The Polk PSW 505 is usually under $200 and is not too bad.
commsysman is offline
