Media centre for 2 channel only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-09-2013, 10:07 AM - Thread Starter
galvs's Avatar
Hi folks.
Asking if there is a device better than WD TV to play lossless audio files without computer, direct from HDs. The WD does not handle 2 big HDs at same time (memory issues?).
Ed
galvs is offline
post #2 of 9 Old 03-09-2013, 01:07 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
What size hard drives are you using? Also, what's your budget? One option would be to use a NAS instead.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #3 of 9 Old 03-09-2013, 01:34 PM - Thread Starter
galvs's Avatar
Was using 2 x 1 TB drive. Now running a MacMini, but want to use it for other purposes, not in a LAN.
The goal is a good standalone player, and spend no more than 300/ 400 bucks
galvs is offline
post #4 of 9 Old 03-09-2013, 02:19 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
That helps. Are you looking for another media player or would a blu-ray player work? Many of last year's models and the new gen players offer external HD connectivity. For media players I would check out Popcorn Hour and Dune.
post #5 of 9 Old 03-09-2013, 04:48 PM - Thread Starter
galvs's Avatar
Thanks, I'll check Dune HD Smart H1.
galvs is offline
post #6 of 9 Old 03-09-2013, 06:13 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
Great. Make sure you check out the media players forum here on avs for owner's impressions.
post #7 of 9 Old 03-10-2013, 05:04 AM - Thread Starter
galvs's Avatar
Seems (all of them?) media players focus more on video, leaving no room for an elegant and efficient music playback solution?
galvs is offline
post #8 of 9 Old 03-10-2013, 02:25 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
Yes, it's good that you checked out the forum. I'm not much of a media player guy for music. I generally use my laptop and Media Monkey or JRiver via DAC or AVR for music.
post #9 of 9 Old 03-10-2013, 02:35 PM
TheWind's Avatar
Liked: 30
Post your questions over in the Netgear NeoTV 550 thread. There are some very knowledgeable people posting there. – It does gapless audio playback (but not for .wav files).
I recently got a NTV550 to stream music from a computer to my HT/Music setup, but you can also directly connect a USB (and/or eSata) HD to it. I’m not an expert on this product, and it’s the only “media streamer” with which I have any experience, but after some initial, minor setup hiccups, I’m extremely happy with it. – And for $80 at J&R right now, for my purpose, it's been a really fabulous deal.
FWIW > It’s been discontinued. (Thus, the $80 price.) No Pandora, Mog or Spotify. YouTube doesn’t really work. Etc.
Dave
TheWind is offline
Reply 2-Channel Audio
