Inexpensive noise cancelling headphones to use on planes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-13-2013, 04:45 PM - Thread Starter
RolandL's Avatar
Quoted: 29 Post(s)
Liked: 27
I'm looking for inexpensive (less than $50) headphones that will cancel a lot of the noise coming from the engines on planes. I don't care too much about the sound quality. Just going to use them to watch movies. Thanks.
Cinerama web site:
http://incinerama.com
RolandL is offline
post #2 of 8 Old 03-13-2013, 08:32 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
When you find some please post the link here.
Charlie
chashint is offline
post #3 of 8 Old 03-14-2013, 05:31 AM
Bigus's Avatar
Quoted: 208 Post(s)
Liked: 225
How about foam earplugs, with normal cheap headphones turned up really, really loud?
Bigus is offline
post #4 of 8 Old 03-14-2013, 06:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
You get the function mentioned above, but far better integrated in IEMs - in-ear-monitors.
These are relatively inexpensive, highly reviewed, and I have a pair on order that are supposed to show up tomorrow:
"Sony XBA-1 (XBA1) Single Balanced Armature Driver In-Ear Headphones"
http://en.goldenears.net/12124
arnyk is offline
post #5 of 8 Old 03-14-2013, 07:54 PM
citizen arcane's Avatar
Quoted: 286 Post(s)
Liked: 8390
These are inserted like expandable foam ear plugs; I have some that i use when doing yard work -
http://www.amazon.com/Koss-Plug-In-Ear-Headphones-Black/dp/B00001P4XA
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #6 of 8 Old 03-16-2013, 02:17 AM
silvrbill's Avatar
These are the ones I use.......
http://www.protravelgear.com/products/Plane-Quiet-Platinum-Headphone-Featuring-New-Solitude-Technology.html
On short flights (2-4 hours) they work great but many of the flights I take are 8-10 hrs long.
The problem on the long flights, especially when I have to take two 8-10hr flights in a row, is that they tend to makes your ears sore from the pressure of the cups against your ears.
I use them sparingly on the longer flights, mainly when I want to sleep or watch TV.
silvrbill is offline
post #7 of 8 Old 03-16-2013, 12:19 PM
mraub's Avatar
These get good Amazon reviews:
http://www.amazon.com/Audio-Technica-ATH-ANC23-QuietPoint-ear/dp/B004K09H32/ref=wl_it_dp_o_pdT1_nS_nC?ie=UTF8&colid=2AE7MYGATTL6V&coliid=I12FDPDW0CNT40
Like a previous poster noted, on the ear headphones can get uncomfortable on very long flights.
MIKE
For every complex problem, there is a solution that is simple, neat, and wrong.
--H. L. Mencken
mraub is offline
post #8 of 8 Old 03-21-2013, 09:27 PM
kohlgren's Avatar
Creative EP-630 In -Ear Stereo Headphones is all i buy. i usually get them off ebay for less than $10/pair.
i have bought them for as low as $3/pair in lots of 10 from a china seller and give them to the kids & swmbo for xmas
i fall asleep listening to the radio, i'll take a new pair out of the box and cut off one earbud and use the other to sleep with biggrin.gif
for comfort during long periods of use, use the smallest earpiece adapter, they come with 3 different sizes
science flies you to the moon, religion flies you into buildings.
kohlgren is offline
Reply 2-Channel Audio
