Two possibilities: which way to go? - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2013, 09:10 AM - Thread Starter
herzzreh's Avatar
Let's not discuss brands themselves but rather the setups... I have Selah SSRs as speakers and Emotiva amp.
Possiblity one:
Turntable into Parasound ZPhonoUSB into Emotiva XDA2 DAC via USB cable into the amp
CD player into XDA2 into the amp
Squeezebox into XDA2 into the amp
Possibility two:
Turntable into Emotiva USP1 preamp into the amp via analog
CD player into the USP1 via analog then into amp
Squeezebox into USP1 via analog then into amp
What would you do and why? Looking into squeezing most SQ out (naturally).
herzzreh is offline
Old 03-21-2013, 11:41 AM
A9X-308's Avatar
Quoted: 1300 Post(s)
Liked: 964
2. I'm seeing no advantage to the additional A/D/A stages in 1.
A9X-308 is offline
Old 03-21-2013, 11:57 AM - Thread Starter
herzzreh's Avatar
In 1, every output would be digital either via USB, optical or coax...
herzzreh is offline
Old 03-21-2013, 12:18 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Don't see any benefit to that. If you were using a digital processor with useful features like bass management or system optimization implemented digitally, then there would be some obvious advantages. As things sit, you're just buying two DACs for every one that you absolutely need.
arnyk is offline
Old 03-21-2013, 12:24 PM
A9X-308's Avatar
Liked: 964
No, every output into the power amp will be analogue. As the TT output is already analogue, what is the advantage in converting it to digital and then back to analogue?
A9X-308 is offline
Old 03-24-2013, 10:02 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Don't forget that you need a phono preamp stage with RIAA equalization, as the raw output from the turntable/cartridge is not a usable signal.
The sound on a record has the bass severely de-emphasizsed and the treble boosted according to the RIAA curve, and is not listenable as is, even if amplified enough.
commsysman is offline
Old 04-24-2013, 06:51 PM - Thread Starter
herzzreh's Avatar
True, but won't I have to rely on good DA conversion in the source then? For example, Squeezebox sounds fine, has a good converter but the old DVD player I use as CD player has crappy DA converter...
herzzreh is offline
Old 04-25-2013, 07:32 AM
A9X-308's Avatar
Liked: 964
^^ How do you know the DVDP has a poor DAC? Measurements or hearsay?
A9X-308 is offline
Old 04-25-2013, 08:09 AM
aquaphile's Avatar
I hate to echo the masses, but this has me scratching my head as well confused.gif
Unless you plan on using the phono pre's USB out to transfer to your PC/make digital copies, just use the analog out on the pre.... or any other phono pre you may choose.
Also, without trying starting a huge debate here, I thought the point of a higher-end phono pre is to "preserve" the TT's analog signal. Going to digital back to analog would (probably?) void out any benefits/sound quality from your phono amp.
2.0 > 7.1
aquaphile is offline
Old 04-25-2013, 08:45 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Possibilty #1 makes no sense at all to me.
Possibility #2 makes sense.
The Emotiva preamp has a built-in phono stage, so your turntable will be able to plug right into it.
Going through multiple devices and conversions is simply a ridiculous idea, and will result in a loss of sound quality.
Keep it simple and direct.
