Need help with streaming music to my receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 03-22-2013, 03:57 PM - Thread Starter
Stryker412's Avatar
Apologies if this is not the right section for my question. I am hooking up an old receiver of mine for use with outdoor speakers. I'd like to buy some sort of unit that will allow me to send the audio from my iPhone to my receiver. I don't have music on my iPhone I only use Spotify. Does anyone know something that will allow me to do this? I know my brother has a Sonos system but I'm looking for something cheaper.
Stryker412 is offline
post #2 of 20 Old 03-22-2013, 04:46 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
There is the pure i-20 - http://www.pure.com/product/i-20-vl-61429/
I am sure there are cheaper devices if you google but I know this device is mentioned alot.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #3 of 20 Old 03-22-2013, 04:59 PM - Thread Starter
Stryker412's Avatar
Sorry I should have said I don't want to dock it. I want to be able to control it while outside. I just want to send the audio of my phone to a device that is hooked to my receiver. Preferably via wifi. I don't think Bluetooth will have the range.
post #4 of 20 Old 03-23-2013, 05:43 PM
mwecksell's Avatar
Any apple Airplay device will work. If you don't want to replace your reciever with an airplay enabled model, get an applets for $100, or an airport express for less. My 6 year old airport express was purchased to be a wireless print server, and has since been retired to the living room as a source for my audio there. It even has optical audio out.
mwecksell is offline
post #5 of 20 Old 03-24-2013, 07:02 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
I too would suggest an Apple Airport Express if your receiver has an optical digital input.
lulimet is offline
post #6 of 20 Old 03-24-2013, 05:22 PM - Thread Starter
Stryker412's Avatar
Does the Airport express require a constant ethernet connection? The receiver for outside will be situated in our laundry room and there are no ethernet connections anywhere near it. I was hoping I could set the Airport up through a wired connection then unplug to be wireless. Can this be done?
I see the old version is available for $80.
http://www.adorama.com/ACAEXPBS.html?gclid=CP6sw5TQlrYCFUVN4AodkAIAFA
post #7 of 20 Old 03-24-2013, 07:52 PM
rntlee's Avatar
Do you own an ipod? Connect it to your receiver, control Spotify on it via your iphone with this.
I do something similar with my iPod, a Pure i20 dock and my iPad, but i'm using Rdio and Remotedio.
rntlee is offline
post #8 of 20 Old 03-24-2013, 08:19 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
The Apple AE does not require an Ethernet connection, a stand alone device that only needs access to WiFi. I have three AEs at home. I think an AE is pefect for your needs. You can access AE seemlesly with an iPhone or iPad. Check the Apple sight for refurbs, essentially new units.
stevensctt is offline
post #9 of 20 Old 03-24-2013, 08:46 PM
fatuglyguy's Avatar
Quoted: 337 Post(s)
Liked: 759
Definitely get an Airport Express, you can score used ones pretty cheap on ebay. I got a previous-generation one (A1264) in great condition with the original packing/documentation for $60 there. Just be careful which one you buy, I believe you have to stick with one of the wireless-N models in order to stream directly from your phone (I know that at least some of the older units do not allow streaming from direct from your phone, but a computer only -- not sure at which model the cutoff is).
desktop + headphone Sonus faber Toy monitor|REL T Zero|Sony UDA-1|Sony MDR-Z7|Sony MDR-1000X|Audioquest NightHawk|Ultimate Ears Triple.fi 10|Sony NW-A35
ht Sony A1E 65" OLED|Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Sony UBP-X1000ES|Sonos Connect + Peachtree Audio DAC•iT|Panamax M-5100PM
stereo Sonus faber Olympica II|REL S/5|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony 43" X800D|Sony UBP-X800|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
post #10 of 20 Old 03-25-2013, 08:39 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
A better value can be had from the Apple Refurb Store. Current gen AE is $85, previous gen is $69. Full warranty plus 90 days tech support.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #11 of 20 Old 03-25-2013, 09:47 AM
rntlee's Avatar
Can't you only stream iTunes to an AE? He wants to use Spotify as he has no music on his phone.
rntlee is offline
post #12 of 20 Old 03-25-2013, 10:58 AM
fatuglyguy's Avatar
Quoted: 337 Post(s)
Liked: 759
Sporify app on an iOS device + AirPlay would do the trick.
Like I said, original (wireless-G AE units -- I believe) will only stream iTunes and only from a Mac or PC. Not so with newer units.
And those are indeed very good deals on refurb AEs. Wish I would have thought about visiting the apple website before I bought mine.
post #13 of 20 Old 03-25-2013, 08:15 PM
White fish's Avatar
So when you say stream directly from you phone do you mean without wifi
And maybe I'm not seeing something in the pics on the net but I don't see an optical port
been working for awhile and still to shy to post my own build thread
White fish is offline
post #14 of 20 Old 03-25-2013, 09:38 PM
fatuglyguy's Avatar
Quoted: 337 Post(s)
Liked: 759
No, the iOS device would need to be connected to the same network that the Airport Express is on. E.g. -- on my iPhone, double-click the home button, swipe left, tap the AirPlay icon, and you're streaming whatever's playing on your phone.
The Airport Express has a single audio out that doubles as an analog 3.5mm out or a mini-Toslink digital out; it isn't a full-sized optical connection.
post #15 of 20 Old 03-27-2013, 05:51 AM
mwecksell's Avatar
Airport express, any generation, will support full audio streaming from any Airplay enables iOS device or iTunes on a Mac or pc. Any app on your iPhone - spotify, pandora, music - will send audio over. The old ones ony support whatever wifi flavor (b, g, n) was current when they were released.
post #16 of 20 Old 03-27-2013, 09:01 AM - Thread Starter
Stryker412's Avatar
I think I'll get the AE. My only concern is if one day I ever go to a non-iOS device I'll be back where I am now. However I still have 1.5yrs on my contract, plus my wife now wants a Macbook..... smile.gif
Since it'll be going in the laundry room I think the older generation model will be best. Is there any reason that I would need the newer model?
post #17 of 20 Old 03-27-2013, 08:37 PM
White fish's Avatar
ok so we dont want the A108x (the G wifi)
but which one is better the A1264 (1st gen) or the A1392 (2nd gen)
post #18 of 20 Old 03-28-2013, 10:48 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
If you need dual-band, the new one. Otherwise, it doesn't matter.
mcnarus is offline
post #19 of 20 Old 03-30-2013, 11:27 AM - Thread Starter
Stryker412's Avatar
I ordered the previous gen AE and it's already shipped out. One more question, is there a way to send only the audio to the AE while watching a movie? I want to test showing movies outside and will hook the iPad to a projector but need to send the audio to the AE for our outdoor speakers. Can this be done?
post #20 of 20 Old 04-05-2013, 05:14 AM - Thread Starter
Stryker412's Avatar
Hooked up the AE last night and everything is working as I wanted it to. Thank you all for the suggestions.
Reply 2-Channel Audio
