Question for 2 channel integrated AMP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-24-2013, 08:46 AM - Thread Starter
phcpbl's Avatar
My powered subwoofer manual suggested that connect main speakers to integrated amp's SPEAKER OUT, connect subwoofer to its LINE OUT . It said "using this method,your main speakers will recieve full range singals from your amplifier and you have the advantage of adjusting the subwoofer's crossover to match any main speaker you currently own."
My question is that when I use the SPEAKER OUT to push main speakers, is there still signals coming out from the LINE OUT port?
phcpbl is offline
post #2 of 2 Old 03-24-2013, 09:03 AM
commsysman's Avatar
Quoted: 1020 Post(s)
Liked: 531
That is the case with most units.
There might be a few exceptions.
If you experience any problems, running wires from your speakers to the high-level inputs of the subwoofer will work just as well.
commsysman is offline
Reply 2-Channel Audio
