Some nice headphones for $75 or less? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Chronoptimist
post #1 of 24 Old 03-27-2013, 06:35 PM - Thread Starter
TheGrumpyCat's Avatar
Quoted: 13 Post(s)
Hopefully I'm on the right forum. I don't want to spend too much money. I will be using them for just music and my Playstation Vita. I listen to mainly rap and techno.
TheGrumpyCat is offline
post #2 of 24 Old 03-27-2013, 07:00 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Grado SR60s.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 24 Old 03-28-2013, 10:16 AM
maximumav's Avatar
The new KRK and Shure mid level models are pretty accurate sounding for the pricepoint. I personally am a fan of Audio Technica and they also have some low level Studio (s) series that might work for you.
maximumav is offline
post #4 of 24 Old 03-28-2013, 05:47 PM - Thread Starter
Quoted: 13 Post(s)
I actually got a pair of Sony xb600 headphones for $60 new. Thanks though!
post #5 of 24 Old 03-28-2013, 06:21 PM
White fish's Avatar
in or over ear?
I love my Sennheiser Cx300 for the price
been working for awhile and still to shy to post my own build thread
White fish is offline
post #6 of 24 Old 03-28-2013, 08:35 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #7 of 24 Old 04-17-2013, 05:05 PM
mjcmt's Avatar
I love my Fostex T20rp studio headphones w/ copper plated mylar planar drivers.
mjcmt is offline
post #8 of 24 Old 04-21-2013, 07:01 PM
sonex's Avatar
akg k240 studio in my opinion the most natural sounding budget cans and very comfortable.
sonex is offline
post #9 of 24 Old 04-21-2013, 08:48 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I like my Sennheiser HD 280 pros - I think I paid in that range on a deal.
lespurgeon is offline
post #10 of 24 Old 04-21-2013, 09:39 PM
Chronoptimist's Avatar
Liked: 543
While TheGrumpyCat has decided on the Sony XB600, InnerFidelity's Wall-of-Fame is a good place to start if you are looking to buy headphones at any price point:
http://www.innerfidelity.com/content/innerfidelitys-wall-fame
Chronoptimist is offline
post #11 of 24 Old 04-22-2013, 12:35 PM
ThaiBoxing101's Avatar
Huge fan of the SR60i's from GRADO, but they are not good for bass-heavy material such as rap.
ThaiBoxing101 is offline
post #12 of 24 Old 04-23-2013, 11:38 AM
Grodzman's Avatar
I love Grado SR60s, and I listen to them often, but they're not for rap and techno.
For those two categories, especially techno (I'm a huge EDM fan), I love House of Marley Positive Vibration headphones. Maybe I'm biased since I work for them, but at $60, they're killer at getting low and still perform decently in the mid/high-range of the spectrum.
Grodzman is offline
post #13 of 24 Old 04-23-2013, 11:42 AM
cel4145's Avatar
Liked: 3002
Put the L-Cush pads on the Grado SR60i, and they do quite well with midbass with a little EQ. Not massive, but as good as many bookshelf speakers. I use my Grados to listen to techno and rap. You just don't get those sub bass frequencies. And of course, definitely not for a basshead smile.gif
cel4145 is offline
post #14 of 24 Old 04-23-2013, 10:09 PM
Liked: 543
Be warned: Grados are totally open headphones (no sound isolation in or out) and many people find them painful to wear. I can't wear any on-ear headphones (Grado or other) if I have my glasses on for example. Larger circumaural headphones are fine though.
I don't think their build quality is up to much either - they are not built to the same standards that a pair of Sony/Sennheiser/AKG/etc. headphones are. I really regretted spending as much as I did on GS1000 as a result of that.
post #15 of 24 Old 04-23-2013, 10:27 PM
cel4145's Avatar
Liked: 3002
I wear glasses all the time. I don't have a problem with the Grados. Some closed headphones don't work for some people with glasses either. It's not really an open or closed thing. It's a person thing.
I don't know about the GS1000s, but the SR225i I have seem as a good a build quality as other headphones I have demoed in the same price range.
cel4145 is offline
post #16 of 24 Old 04-24-2013, 05:52 AM
Liked: 543
It's not about being closed/open (that's determined by the outside of the headphones) but whether they are designed to sit on your ears or around them. With glasses, on-ear headphones press your ears against the arms, with ones that sit around your ears that doesn't happen.
I've had SR80, HF2, and GS1000. All of them had similar build quality issues, with the cable being the weakest point. The GS1000 was the most disappointing due to the workmanship on the wooden finish, and costing so much more than the others, and it was ridiculous that the "Head-F1" error on the HF2s made it through quality control. Wouldn't buy from them again.
post #17 of 24 Old 04-24-2013, 06:49 PM
cel4145's Avatar
Liked: 3002
You originally stated that "many people find them painful to wear" and that you can't wear on ear headphones. I've seen many people who do not find them "painful" to wear. As far as on ear, that really depends on the person: head size, how tight you wear them, your ear, the type of arm on your glasses. I find the S-Cush pads just fine with glasses. The L-Cush were a little uncomfortable when I first got them, but handwashing them with mild soap and water broke them to be pretty soft. On the other hand, there are closed headphones that bother me after a while because of how they press on the arm of glasses onto the side of my head. Headphone comfort really is an individual thing in many circumstances.
You are one of the first people I've ever heard complain about Grado cables. They typically have a good reputation. That being said, the newer SR125i and up models (released 2009) now have a thicker, heavier duty cable than the older Grado models and the SR60i and SR80i. Perhaps you are familiar with older Grado models.
cel4145 is offline
post #18 of 24 Old 04-25-2013, 12:51 AM
Liked: 543
While it's true that comfort is a personal thing, complaints seems to be more common with Grado headphones than most. I wouldn't recommend anyone buy a pair without having tried them on first to see if it's a problem for them.
Tom White likes this.
post #19 of 24 Old 04-25-2013, 05:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Interesting. There used to be a plague of people complaining about the comfort of Grado headphones and a big market for earpads to make them more comfortable. I bought a pair of Grado SR60s and they sounded pretty good for the day, but were not competitive for comfort in my opinon. I think that Grado has responded to the market since then.
Earphone and headphone comfort can be a big deal if you wear them in extended sessions.
In the end bass extension and response is facilitated by an air-tight fit. IME open air headphones are either light on bass or produce a lot of bass that gets lost in transmission for a more or less net flat response.
I prefer IEMs for lengthy listening sessions, but the phones I listen to the most are (for convenience) wireless semi-open ear phones - Sennheiser RS 160s which IMO require a fair amount of bass and treble boost to sound balanced.
arnyk is offline
post #20 of 24 Old 04-25-2013, 07:16 AM
cel4145's Avatar
Liked: 3002
Well, that's the tradeoff for increased sound stage of open headphones. That, and open air can be more comfortable than some closed because one's ears can get warm with closed.
cel4145 is offline
post #21 of 24 Old 04-28-2013, 03:14 PM
dwong's Avatar
Sony V6, its a classic and good for everything for me, often on sale at many sites, I got it on sale for $39+tax at Amazon.
Better then my Grado SR125, Sennheiser HD 280 give me headaches after long period.
Actually gave SR125 to sister, she gave it back after listen to the V6 and took the Sony instead. I bought another V6 since then.
I see the atoms free and fine,
That bubble like a sparkling wine;
I see the songs Electrons sing,
Jumping from ring to outer ring;
              - Lister, The Physicist
dwong is offline
post #22 of 24 Old 04-29-2013, 06:02 AM
adamCS's Avatar
Originally Posted by mcnarus View Post
Grado SR60s.
+1
adamCS is offline
post #23 of 24 Old 04-30-2013, 08:27 AM
Badouri's Avatar
Liked: 56
Badouri is offline
post #24 of 24 Old 05-12-2013, 02:52 PM
luv-ma-headphon's Avatar
hi
i would personally go with the award winning sony v55 headphnoes http://www.shoppingway.co.uk/sony-v55 or
at slighter bigger budget but headphones of exceptional studio like quality http://www.amazon.com/Audio-Technica-ATH-M50-Professional-Monitor-Headphones/dp/B000ULAP4U/ref=sr_1_20?ie=UTF8&qid=1368395514&sr=8-20&keywords=headphones
luv-ma-headphon is offline
Reply 2-Channel Audio
