Onkyo 8255 - AVS Forum | Home Theater Discussions And Reviews
Old 04-02-2013, 07:15 AM - Thread Starter
jbudik's Avatar
First time poster...Be gentle!!
Old-school music listener. Just blew up my 33 year-old Technics receiver. Recently purchased online, a simple, inexpensive 2-channel, Onkyo TX-8255. It does everything I need except for one thing. I wanted to hook up an equalizer I have had for years. My past configuration had it connecting to the “Tape 2 ports”. Can anyone tell me if it is possible to make this equalizer work with this receiver?.. Thank you!
jbudik is offline
Old 04-02-2013, 08:54 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
According to page 8 of your AVR's user guide it has 2 sets of ins and outs for tape.
arnyk is offline
Old 04-02-2013, 09:34 AM - Thread Starter
jbudik's Avatar
arnyk.... Thanks for the input! I was just reading and think it can work. I noticed that you need to press and hold the "tape 2" (monitor) button to turn on the tape monitor.. I will try this... Thanks!
jbudik is offline
Old 04-07-2013, 09:32 PM
dspiro's Avatar
I was thinking of purchasing the same unit since my 25 year old Denon Receiver just bit the dust. Did the Tape 2 configuration work effectively as an EQ loop? And do you have to hold it down every time you start listening to a new source? That could be bothersome.
dspiro
dspiro is offline
Old 04-08-2013, 05:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Good question. Having to push that button over and over again will probably get old very fast.
Your remaining options are:
(1) Obtain an AVR with built in equalization which many now have.
(2) Obtain a high end AVR that has pre-out and amp-in jacks, and put your existing equalizer into the system at that point.
arnyk is offline
Old 04-08-2013, 08:56 AM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
I'd vote for option 1. Most AVRs have dropped the ext in feature (Denon), like I used to have on my denon 1909, my 3311 doesn't have it, but it does have preouts for external amps. The AVR seems the best all in one solution. I particularly like the dynamic eq feature which keeps the eq adjusted as the volume is reduced below reference.
glangford is offline
