Networkable 2 Channel Receivers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-08-2013, 08:04 PM - Thread Starter
bareyb's Avatar
Anyone heard of a 2 channel Network Ready receiver with a USB port for iPod?
Obsessed is such an ugly word... We like to think of ourselves as extremely focused.
bareyb is offline
post #2 of 14 Old 04-08-2013, 08:19 PM
gregzoll's Avatar
Liked: 33
There are plenty out there. You just do not hook up the sub-woofer and other sets of speakers.
gregzoll is offline
post #3 of 14 Old 04-08-2013, 11:28 PM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
Onkyo TX-8050
http://www.onkyousa.com/Products/model.php?m=TX-8050&class=Receiver&source=prodClass
Marantz M-CR603
http://us.marantz.com/us/products/pages/ProductDetails.aspx?CatId=hificomponents&ProductId=MCR603
Or you could always do as the previous post says and use a multichannel AVR in a stereo configuration. Plenty of options there.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is online now
post #4 of 14 Old 04-09-2013, 03:22 AM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
LOL, yes they are called AVRs. That is my 2 channel networked reciever (Denon 3311ci).
glangford is offline
post #5 of 14 Old 04-09-2013, 03:37 AM
Nethawk's Avatar
Liked: 118
Except for bass management the above mentioned Onkyo is more flexible in terms of inputs and services than all AVRs but the latest higher end models from Denon or Marantz. It's a solid unit, and more affordable.
Nethawk is offline
post #6 of 14 Old 04-09-2013, 05:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Dedicated 2-channel only receivers are a dying breed. I have not seen a 5.1 ir 7.1 AVR that wouldn't be a splendid 2.0 or 2.a receiver if configured that way.
Once you get over the desire for just 2 channels, the world opens up before you!
arnyk is offline
post #7 of 14 Old 04-09-2013, 05:30 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hmm, here is its stated feature set @ $379
Internet Radio and Music Streaming Service Connectivity (vTuner, Last.fm, SIRIUS XM Internet Radio®, Mediafly, Pandora®, Slacker, Napster, Rhapsody®)
80 w/ch, 8 ohm, 20Hz-20kHz, 0.08% THD, FTC
Direct Digital (USB)connection of iPod®/iPhone®
Compatible with UWF-1 Wireless LAN Adapter (via USB)
Zone2 pre-out
Subwoofer pre-out
Phono Input
Other than the phono input (obtainable with an $50 outboard device)
What is there that can't be found on a $379 AVR or making an allowance for the phono input, a $329 AVR?
It appears to me that the AVR would have one big user-oriented feature that the 8050 lacks: Audyssey. The AVR would also have a far more extensive built-in upgrade path and support for more modern media formats.
arnyk is offline
post #8 of 14 Old 04-09-2013, 07:45 AM
Nethawk's Avatar
Liked: 118
Spotify :-) which is also included in the Onkyo's streaming services. It's a must for me anyway.
I hear ya, I think I'm going to upgrade to a mid-level Denon from this year's lineup just for bass control. My office system deserves it. That said, I have been perfectly pleased with the Onkyo.
Nethawk is offline
post #9 of 14 Old 04-09-2013, 07:54 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Spotify :-)
spotify is available on many avr's in the same price range as the 8050. onkyo alone has it avalaible on the 414, 515, RC460 and probably others that i am too lazy to look up. Denon's new e300 also has spotify.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #10 of 14 Old 04-09-2013, 08:27 AM
Nethawk's Avatar
Liked: 118
I'm not denying that there are others, just stating that for pure 2 channel requirements the Onkyo is pretty well packed with features for the price. Zone 2 pre-outs and 4 ohm compatibility are also included. I've done my research, I have to step up to Denon 2113ci for an upgrade that fits (most of) my needs.
Arny, out of curiosity, what other media formats do you see necessary for 2 channel setup?
Nethawk is offline
post #11 of 14 Old 04-09-2013, 10:24 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Since I use a modern AVR that supports pretty much every format out there, I don't have any issues.
I like that feeling. ;-)
arnyk is offline
post #12 of 14 Old 04-09-2013, 11:12 AM
benfica1's Avatar
Quoted: 14 Post(s)
My issue with using modern avr's for 2 channel audio is you need them connected to a tv/monitor in order to easily change settings or access a setup menu. I'd like to be able to easilt see settings on the receiver screen.
benfica1 is offline
post #13 of 14 Old 04-09-2013, 11:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That varies with the AVR you choose. My Yammy's setup is via the little alphanumeric screen on the AVR.
arnyk is offline
post #14 of 14 Old 04-09-2013, 01:31 PM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
You only need do it once though.
Reply 2-Channel Audio
