Thoughts on this setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2013, 12:00 PM - Thread Starter
EdwinwNg's Avatar
Just wanted to hear some thoughts on this setup I am thinking of getting, and wanted to see if maybe I should swap some things out.
2 Polk Audio tsi500
Denon 1913 AVR
BIC PL-200
It is mainly for music, and then movies. I'd say 70/30. The room size is large, I don't have exact dimensions but it is a living room / dining room combo and open to the kitchen so it is essentially just all one room, with high ceilings about 10 feet.
I actually would prefer some bookshelf speakers around the same price range as the polk audio towers but I can't find any so far that I've seen that seems to provide some good midrange, unless any of you have suggestions. Am willing to spend a little more if it's really worth it though.
My current setup is a pair of Audioengine A5+ with the Bic F12 sub, I would be selling this to my friend.
EdwinwNg is offline
post #2 of 4 Old 04-18-2013, 12:11 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I have almost this same exact setup. Only difference is I use monitor 70s and the matching center channel.
I think it's pretty good for the budget.
DotJun is offline
post #3 of 4 Old 04-18-2013, 12:19 PM - Thread Starter
EdwinwNg's Avatar
Anything you wish you had changed, or will change? you satisfied with it?
EdwinwNg is offline
post #4 of 4 Old 04-18-2013, 12:25 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
2 Polk Audio tsi500
Denon 1913 AVR
BIC PL-200
Ever look at this blind study?
http://dl.dropboxusercontent.com/u/16343460/New%20Evidence%20that%20High%20School%20and%20College%20Students%20May%20Prefer%20Accurate%20Sound%20Reproduction.key.pdf
arnyk is offline
Reply 2-Channel Audio
