Itunes - How do I get the subwoofer involved? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-22-2013, 10:15 PM - Thread Starter
marfpilf's Avatar
I'm playing mp3s through home theater setup off of my computer but the subwoofer doesn't seem to engage. I know there are only two channels in an mp3 but I was wondering if there is some piece of software or different audio player that would act as a crossover and actually engage my subwoofer. Maybe it is just a Windows setting?
I'm running Windows 8
My Sound is passed through my Marantz s5006 receiver via HDMI coming from my Geforce 560 Ti.
Thanks for reading!
marfpilf is offline
post #2 of 8 Old 04-22-2013, 10:27 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3081
If you're using EQ then the subwoofer is engaged in stereo mode. What settings are you using? Audyssey engaged? Direct? Pure Direct?
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 8 Old 04-22-2013, 10:32 PM - Thread Starter
marfpilf's Avatar
As far as Direct and Pure Direct go, I'm assuming these are modes on my receiver. If that assumption is correct, then it is set to "auto" (my other two options are "direct" and "pure direct".
When you say "if you're using EQ then the subwoofer is engaged in stereo mode". Which EQ do you mean?
marfpilf is offline
post #4 of 8 Old 04-22-2013, 10:35 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
I have an older marantz sr5003 and had same issue.
1st- don't use "direct" or "pure direct"
2nd- make sure your speakers are set to "small" and
Sub to yes.
Good luck.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #5 of 8 Old 04-22-2013, 10:52 PM - Thread Starter
marfpilf's Avatar
Hi grasshoppers,
I'm not using "direct" or "pure direct" to my knowledge. My speakers are set to small and the subwoofer is set to "yes".
Still sounds the same. How did you fix the issue with your sr5003?
marfpilf is offline
post #6 of 8 Old 04-22-2013, 11:03 PM - Thread Starter
marfpilf's Avatar
Thanks for the tips you guys. I found the issue... the rca to the sub was a little loose so it wasn't even emitting a test tone. Reconnected it and it is much better. Shame it is 1am and I can't really test it all that loud smile.gif
Thanks again.
marfpilf is offline
post #7 of 8 Old 04-23-2013, 09:40 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3081
Glad you got it sorted out. Everything seemed in order regarding settings and connections.
post #8 of 8 Old 04-24-2013, 06:54 AM - Thread Starter
marfpilf's Avatar
Now I just need to remember to shut off the sub before playing with the cables so I don't scare the whizz out of myself when it blasts off upon reconnection...
Thanks for the help all.
marfpilf is offline
Reply 2-Channel Audio
