Recommendation please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-02-2013, 03:53 AM - Thread Starter
gsusser's Avatar
I'm in the process of updating 12 or 13 year old equipment. I have a 200 watt per channel Monster amp and Rotel pre-amp. I want to go the route of an integrated amp and am looking for the same clean, crisp and powerful sound I have now. I want 2 channel, at least for music, and am willing to live without surround for TV. Ideally, the amp will have a phono stage. It will be used with my TV, music (source = hard drive on computer and iTunes), TiVo, DVD player and turntable. My budget is under $2000.
Speaking of connecting my computer, it's a fairly simple connection now. A cable running from my computer to a cheap DAC to the receiver. How important is the DAC? What is recommended for under $500?
Meanwhile, what the heck do I do with my old equipment? Some of it is quite heavy (I can't even lift the Monster amp!) In addition, I have 2 working Rotel pre-amps, B&W center speaker, quality subwoofer (I forget the make) - all about 12 or 13 years old.
Many thanks!
gsusser is offline
post #2 of 5 Old 05-02-2013, 06:56 AM
glangford's Avatar
Quoted: 199 Post(s)
Liked: 170
For 2 grand I'd consider the yamaha as2000 or the hk990. Another possibility would be a high end avr, the denon 4311 or 4520. As far as dac goes, you could just use the avr internal dacs.
glangford is online now
post #3 of 5 Old 05-02-2013, 07:49 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
For a DAC, look into the ODAC. It was designed to compete with more expensive DACs.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 5 Old 05-03-2013, 05:10 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Forget about integrated amplifiers, they are relics of the past, just as much as your old monster separate pieces of equipment.
If you want a simple,clean powerful modern 2 channel system, then you will set up a 2.1 channel system based on a modern AVR. This will give you the best sound quality at any reasonable price, and certainly for the $2000 or less that you are budgeting.
DACs are usually totally unimportant as separate components in modern audio systems. The only reason to have a separate DAC would be if it were impossible or impractical to obtain a good AVR that has one built in. To the contrary, finding AVRs with good built in DACs is very easy.
In the old school people obsessed over details like amplifiers and DACs. We now know that the most critical parts of an audio system from a sound quality perspective are the room, the speakers and how the electronics are used to optimize them.
If I were budgeting $2000 for an audio system I would budget $500 for electronics, $1000 for speakers, and leave a $500 allowance for optimizing room acoustics. Of the $1,000 for speakers, at least half of it would be for a good subwoofer.
Once you wrap your mind about that, we can talk about specifics.
As far as disposal of the old gear goes, if it is in good shape, what about Audiogon or eBay?
arnyk is offline
post #5 of 5 Old 05-03-2013, 08:30 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The Rotel preamp is probably going to be hard to beat for sound quality.
Putting a better power amplifier than you have with the Rotel preamp with it would be a good way to go, but it sounds like you want to simplify and eliminate the separates.
I have an excellent Musical Fidelity M3i integrated amplifier for sale that might be exactly what you need. See the classified ads here at AVS for more details.
You didn't say much about what type or size speakers you want, so that is another whole area to consider.
You also don't make it clear whether you have a turntable or need to buy one.
You don't really make it clear what that $2000 is going to need to be used for.
commsysman is offline
Reply 2-Channel Audio
