B&W 685s/Pro-Ject TT: Integrated Amplifier Recommendation - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 05-15-2013, 05:02 AM
Paraneer's Avatar
Quoted: 40 Post(s)
Liked: 92
I agree with the above poster. Bi-amping serves no purpose whatsoever. But to answer your question, no you cannot with the unit you are considering. It a 2 channel amp only and has no unused internal amps to use like an AVR. Even with an AVR, bi-amping by using the unused channels brings no benefit.
Just hook up your B&W's to the Marantz normally and enjoy the music!
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #32 of 32 Old 05-20-2013, 06:03 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
OP- do you also have a theater setup? If not, I would recommend buying a nice home theater receiver or pre/pro with
room correction as I believe that something like the Denon AVR-3312 or AVR-4311 would equal the Marantz that you are currently looking at, plus it would provide the opportunity to purchase an HTM1D or an HTM2D to go along with those 805D's. That would give you a hella nice theater and 2 channel setup all in one!
Martycool007 is offline
Reply 2-Channel Audio
