Harman Kardon 3490 vs Yamaha A-S500BL - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 06-19-2013, 10:51 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Originally Posted by lacrimosa7 View Post
Thank you everyone for your replies! biggrin.gif I think I am going to go for the HK as it has all the power I will probably ever need, I love the looks, and to be honest, I just feel more comfortable with it for some reason. I plan on getting an HD 990 for my new CD player, hooking up my parents old equalizer - since the HK has the proper inputs - and then topping it all off with a new pair of Polk TSI100Bs.
Thank you all so much again for your replies!
-Josh
I've had an HD 990 for about 2 years, running it into a Rotel/KEF 2-channel. Best CD player I've ever had. Also got mine about 1/2 of list. Wish I could afford the matching amp.
I'd call H/K the default 2-channel receiver these days for good reason. I'd say it is the best mid-priced option around for most use cases.
lespurgeon is offline
post #32 of 36 Old 06-20-2013, 06:13 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I will also recommend the LSi7 from the Polk Ebay store, I have heard the LSi9 and they sound wonderful, the tweeter is phenomenal.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #33 of 36 Old 06-24-2013, 08:11 PM
223 ackley's Avatar
Does the 3490 sound significantly better than the 3480 ? I have a Denon DRA-397 that has far better resolution and overall better sound than my 3480 playing into PSB B25s. Is watt hi fi wrong about the Yamaha ? Also, where does NAD stand in this group ?
Thanks Bruce
223 ackley is offline
post #34 of 36 Old 06-24-2013, 08:35 PM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
I can't compare my 3490 to anything as it's the only 2 channel receiver I've owned, but I think it sounds awesome. Right now I'm listening to Eddie Van Halen on Vinyl through it. Simply superb.
Tweaked05 is offline
post #35 of 36 Old 08-15-2013, 10:57 AM - Thread Starter
lacrimosa7's Avatar
Just an update!
I picked up the HD990 from eBay for 275.00 as an open box. The previous owner had only used it for photography purposes, and it hadn't even been plugged in. I have decided to go with Paradigm Monitor Pro bookshelves for my new speakers! They sound amazing, and the HK3490 doesn't even seem to break a sweat with them.
Sir4K likes this.
lacrimosa7 is offline
post #36 of 36 Old 08-23-2013, 11:53 AM
Sir4K's Avatar
Originally Posted by glangford View Post
When I went to Yamaha's site to check, they make no mention of 4 ohms on any of that line until you get to the AS-1000. The 500 and 700 they clearly spec at 8 ohms.
You're wrong.
http://uk.yamaha.com/en/products/audio-visual/hifi-components/amps/a-s500___g/?mode=model
It covers 4 ohms.
Had to sign up and clear this up so that people googling don't get incorrect information like I did.
Sir4K is offline
Reply 2-Channel Audio
Yamaha A S500bl Integrated Stereo Home Theater Amplifier Black , Harman Kardon Hk 3490 120 Watt Stereo Receiver , Harman Kardon , Yamaha , Yamaha Brand , Yamaha Electronics , Polk Audio , Onkyo
