Please Help, keep blowing speakers... - AVS Forum | Home Theater Discussions And Reviews
Old 06-14-2013, 11:27 PM - Thread Starter
yaakmt's Avatar
First of all thank you. I have had this system since 2001. It was my sept 11 get the economy back purchase. Anyhow its a Denon DRA295 driving a pair of Klipsch SF1 speakers. I am using my ipod on the headphone jack with a monster cable. Speaker wires are smallish and fairly long. I first bought in a small little condo but now have a small house that is very open I have the speakers upstairs in the loft facing the living room/dining room. Seems fine when the volume is at 0 but any extended play at +10-18 blows out the woofer on one of the speakers. I have replaced one but now one of them is blown again. The Denon is 50 watts X2 and 8 ohm. The speakers are 100 watt and 8 ohm. Theoretically should be ok? No? Does turning the receiver past 0 to the plus side increase the watts from 50? What am I doing wrong?
Thank you very much,
BC
yaakmt is offline
Old 06-17-2013, 01:18 PM
RCbridge's Avatar
Quoted: 16 Post(s)
[QUOTEI am using my ipod on the headphone jack with a monster cable][/QUOTE]
How are you doing this?
Do you have the problem while playing the Radio?
RCbridge is offline
Old 06-17-2013, 02:54 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
you are more likely to damage speakers with an underpowered amplifier than an overpowered amplifier. Turning an amplifier louder than it can go will clip the signal and damage the speakers.
It's also possible you damaged your amp if you turn it that loud.
It's strange that your woofers are breaking and not your tweeters. What exactly do you mean by they get "blown" like does the actual material split or is the rubber breaking or what?
JWagstaff is offline
Old 06-17-2013, 03:35 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
If you are hearing a lot of distortion, you are pushing the amplifier too hard. That is one issue.
A 50 watt amplifier can put out more than 50 watts when it is distorting. Remember, the 50 watt rating is max output WITHOUT any significant distortion.
On the other hand, it is more likely that the speakers are not really able to take nearly as much CONTINUOUS POWER as you think,, because of the age of the cones.
If you get new drivers from Klipsch and install them, they will no doubt hold up better than the 10-year-old ones.
Klipsch does rate them at 100 watts RMS continuous power when new, and even with high distortion your amp can't quite do that much.
commsysman is offline
Old 06-17-2013, 03:57 PM
MarkHotchkiss's Avatar
Liked: 85
Hi BC,
Welcome to the forum.
Originally Posted by yaakmt View Post
. . . I have replaced one but now one of them is blown again. . .
Another possibility:
Is the second blown woofer on the same channel as the first? If so, then one possibility is that the Denon has too much DC bias on that channel's output.
If you have a multi-meter, disconnect the speakers, and with no signal going into the amp (volume all the way down), measure the DC voltage at the speaker terminals. It should be near zero, and if it's not, then that voltage will be heating the voice-coil in your woofer. You would then need to get the Denon repaired.
MarkHotchkiss is offline
Old 06-18-2013, 09:22 AM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
What is the volume scale of that Denon? My HK's go from like -50 to +10. Is +10 near the maximum usable volume from that receiver? If so, you are likely distorting the signal from the receiver to the speaker and that can blow speakers.
Tweaked05 is offline
Old 06-18-2013, 09:46 AM - Thread Starter
yaakmt's Avatar
Thanks! Not sure if its the same speaker or not. I havent taken it apart yet but on the previous speaker it ripped around the base. It sounds ok on lower power but up to 0 it get crackly. Volume range on the Denon is -60 to +18. Even at +15 I dont think its super loud. My house is very open with a open loft upstairs, so maybe more power is needed anyway? Thank you so much! Ill check the DC output tonight.
Thanks again,
BC
yaakmt is offline
Old 06-18-2013, 09:50 AM - Thread Starter
yaakmt's Avatar
The Monster cord plugs into the cdr/tape input with two connectors. On the other end it plugs into the ipod headphone jack. I turn the ipod up all the way. then adjust sound via volume on the receiver.
yaakmt is offline
Old 06-18-2013, 10:02 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
If I turned my Denon to +15 it would probably just shut off from trying to draw too much power. If not, it would probably just start burning.
Old 06-28-2013, 08:32 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
You are pushing the avr to hard. Buy more power!
derrickdj1 is offline
Old 06-29-2013, 05:30 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Ripped around the bass speaker? Sounds crackly at high volumes? You are perfectly describing a speaker that died due to old age.
The speaker surround disintegrated. If one speaker in a set failed this way the rest of the speakers in the set will likely fail the same way within a month or two.
Alll things considered, your best next move may be a new set of speakers. Upgrade!!
How old are those old speakers anyway?
I've had a number of speakers fail this way over the years. Coincidentally my Paradigm 12" subwoofer failed this way yesterday. It was maybe 10-15 years old. I don't know exactly because I obtained it used. I replaced the subwoofer driver with a good subwoofer driver, but not necessarily a proper replacement. I I had it laying around the house. It's better but probably not exactly right.
I had just ordered a new set of Integrity subwoofer drivers. I am going to start building the new boxes on Monday. They coincidentally showed up yesterday.
arnyk is offline
