Advice on a 2.1 setup for small space. - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2013, 07:08 AM - Thread Starter
gquinones83's Avatar
I was hoping on some feedback for the following system that I'm planning on setting up. My living space is small so really my only option is a 2.1 setup (about 15'x10' lving room). So I've been doing some research and have narrowed down these items to fit within my budget and my needs. My question to you guys is if this setup is appropriate for what I'm looking for. I really just want good definition to the sound coming from my ps3 and home theater pc (media server), I'll be connecting these devices to a Panasonic Viera tcp50st60. So the items in question are:
Receiver:
Denon AVR-1312 -$128 refurbished from A4L
http://www.accessories4less.com/make-a-store/item/DENAVR1312/DENON-AVR-1312-5.1-Channel-A/V-Home-Theater-Receiver/1.html
Subwoofer:
BIC F12 - $200
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/product-reviews/B0015A8Y5M/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Bookshelf Speakers:
I was originally going to go for these Dayton B652's but reading recent amazon reviews indicate that the manufacturer has changed the quality of their builds resulting in a sub-par speaker
Dautpm B652 - $40 for the pair
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-652
But on the other hand I have room to spend a bit more on the bookshelves because from what I understand this is where the majority of the sound will be coming from and you don't want to skimp on these.
Pioneer SP-BS22 - $130 for the pair
http://www.parts-express.com/pe/showdetl.cfm?partnumber=250-656
This puts me at $458 max and my budget is no more than $600. Any suggestions from the community would be greatly appreciated! Also, please advise if I'm posting to the wrong sub, I'm new and I thought this was the most appropriate one.
gquinones83 is offline
Old 07-05-2013, 08:34 AM
crn3371's Avatar
Quoted: 242 Post(s)
Liked: 194
The Pioneer speakers get good reviews, so I'd go with them. I'd check around for pricing as I've regularly seen them for $77 a pair (Fry's).
crn3371 is offline
Old 07-05-2013, 09:38 AM
postrokfan's Avatar
Quoted: 539 Post(s)
Liked: 3237
If I were you I would spend just a little more on the receiver and get the 1613 or the 1612 to get Audyssey MultEQ calibration software. This will give you much better SQ and is worth the extra money. The BIC F12 should be great for movies and games. The BS22s are also a good choice and you should be able to find them for less than $130. You can use the cash saved to get the better receiver.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 07-05-2013, 11:33 AM - Thread Starter
Thank you crn3371 and postrokfan for the quick replies. A quick search led me to amazon where I was able to find them for $99! Fry's had them for the same $130.
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG
I'll take the advice and upgrade to the 1613, this bring me up to around $515 total, still under budget.
Thanks again for your help!
Old 07-05-2013, 12:53 PM
postrokfan's Avatar
Quoted: 539 Post(s)
Liked: 3237
That should be a nice little budget setup. Enjoy!
