Room Correction for 2-channel system - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2013, 11:49 PM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 59
I have been pondering room correction for a 2-channel setup, I have my yamaha amp in there now and the YPAO is no longer functional so it doesn't sound so hot, the setup was just temporary to see if I like enough to start buying components and I do so I am going to start with some Legacy Focus SE speakers. I realize I could use a Denon AVR-X4000 with its Audyssey and that receiver has low level outputs to run to separate amps for the speakers. I am wondering what other methods folks use? Are there preamps with Audyssey or some other room correction solution built-in?
larry7995 is offline
Old 08-10-2013, 05:27 PM
Tweaked05's Avatar
Quoted: 42 Post(s)
Liked: 26
I'd be interested in an inexpensive room correction device to place in between the pre and post amps of my HK 3490.
Tweaked05 is offline
Old 08-14-2013, 09:46 AM
alexwgoody's Avatar
alexwgoody is offline
Old 09-25-2013, 10:26 AM
CV580DRVR's Avatar
Liked: 27
Does somebody need a Behringer DEQ-2496 in really sweet/new condition?
Just so happens.....I have one tucked away with nothing to do!
Shoot me a PM.....I can work with you on a nice deal.
CV
CV580DRVR is offline
Old 10-02-2013, 01:38 PM
tomorrowsbishop's Avatar
Integrated room correction is inaccurate. You can go manual. True RTA Analyzer software and a decent mic. I've use True RTA and a Sony ecm-907.
True RTA
http://www.trueaudio.com/rta_abt1.htm
All in all EQs don't really help. Try different cables and speaker placement.
tomorrowsbishop is offline
Old 10-03-2013, 06:51 AM
commsysman's Avatar
Quoted: 978 Post(s)
Liked: 526
The fashion is to try and substitute room correction programs for proper placement of the main speakers; this is the worst thing you can do IMO.
There is no substitute for getting the main speakers placed correctly in the room, WITHOUT using any room correction at all.
JOB ONE in getting things to sound right is to move your two main speakers around until the bass linearity and imaging are the best.
A few inches can make a lot of difference.
No software can make the speakers sound right if they are in the wrong location. All of them also do digital signal processing which tends to degrade the sound.
Any processor you put in the signal path is likely to reduce sound quality to some degree.
It may be able to do something once they ARE in the correct location, but even that is not always true. Sometimes it is worse than nothing.
It may be a bit tedious to keep testing different locations for your speakers, but it is the ONLY way to get the best sound quality in your room.
commsysman is offline
Old 10-03-2013, 07:06 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Check out the MiniDSP web site..
http://www.minidsp.com/
arnyk is offline
Old 10-04-2013, 05:30 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I would invest in some room treatments such as absorbing panels on the side walls and front walls, bass traps in the corners, and a decent AVR that has room correction software.
Larry, you have a PM from me!
Martycool007 is offline
Old 10-04-2013, 07:29 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Room EQ makes a significant difference... Speaker placement is crucial to enhancing SQ, but changing cables... don't lie to people rolleyes.gif
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 10-05-2013, 09:47 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Room EQ can also take away from your sound and speakers. What I recommend is going with GIK Acoustics and getting proper room treatment. Their package starts at $500.00. Well worth the money.
NAIM101 is offline
Old 10-06-2013, 07:07 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 59
I am going to get a 6x10 area rug for that room and some acoustic panels. My new latest project is a 2-channel listening room in the vaulted area of the house, everything sounds better in there. Going to base that on a pair of Legacy Focus SE speakers, a couch with recliners at both end and go from there! Heading over to Rocky Mountain Audio Fest next weekend to get some ideas! Being a Fed, I can't afford to buy anything until I know I am going to get paychecks again...
Old 10-06-2013, 06:12 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Can you do us all a favor and put down your favorite 3 rooms and give us your thoughts after the show? Definately check out Vapor Audio's room.
NAIM101 is offline
Old 10-12-2013, 08:02 AM - Thread Starter
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 59
See what I can do, I am getting ready to head over their soon.
Old 10-16-2013, 06:44 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Anything done poorly can take away from SQ.
Statements like "Room EQ can also take away from your sound and speakers" can be true, but are often false, Thus, they are generally unhelpful.
Seems like this thread is spinning into a battle between system eq and room acoustics.
Taking either side is like flunking an IQ test, because you need both to have really good SQ no matter what your room is or how good your speakers are.
Brands, schmands!
One of the most significant costs of effective sonic treatments on the scale of most listening rooms is shipping costs. If you can learn enough to effectively use products you can obtain from a local supply house (who probably also sells thermal insulation) you will obtain your most cost effective solution. Rooms are enough different that I don't know how well a prepackaged solution will do.
arnyk is offline
Old 10-16-2013, 06:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Rugs are about the worst sound treatments there are. To be walkable they have to be too thin to be anything like broadband absorbers.
arnyk is offline
Old 10-16-2013, 09:33 PM
Correction, cables doesn't help with receivers but it does with real audio equipment. Cables aren't an accessory they are components. Most audio stores will let you borrow cables the hear the difference. It an easy sale.
As for me EQ's don't help.
Old 10-16-2013, 09:42 PM
Hamilcar Barca's Avatar
Cables are simple conductors. Any cable, suitably matched to the application, is sonically indistinguishable for any other. Admittedly, overpriced (and sometimes grossly overpriced) bundles of copper strands wrapped in insulation may be an easy sale; the sale isn't due to any audible characteristic. They're selling status symbols.
67jason likes this.
Hamilcar Barca is offline
Old 10-16-2013, 10:18 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Evidence please.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Old 10-16-2013, 10:20 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
+1000
67jason is offline
Old 10-17-2013, 07:25 AM
Liked: 1319
Copper is copper. You aren't hearing anything different and this advice is simply misleading. You can buy an expensive cable because it looks cool, but if you think it sounds different than you are a victim of the placebo effect.
Brownstone322 likes this.
Old 10-17-2013, 09:14 AM
Brownstone322's Avatar
Quoted: 42 Post(s)
Liked: 108
This is one thing about "audiophile" culture in general -- and sites like this in particular -- that sometimes makes me wanna abandon this hobby.
If you wanna believe that swapping cables provides audible differences while those same differences are somehow (perhaps magically) immeasurable, then that's your business. It neither picks my pocket nor breaks my leg. But to come here and recommend that kinda hokum to complete strangers? To encourage them to spend their money that way? That's just bizarre. Unethical, in my mind.
Some people I get. For instance, I get that phonies like Robert Harley and Harry Pearson are running a magazine and will say anything to perpetuate the culture and make a buck; I think most of us understand their game up front. But what would be your incentive for promoting the scam? Is proselytizing the religion that important to you?
Brownstone322 is offline
Old 10-20-2013, 12:32 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I take it you sell cables? Something you pick up at Home Depot and re-brand at 4000% mark-up no doubt.
lespurgeon is offline
Old 10-20-2013, 01:28 AM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Hello Larry, can you give us your review of the top 3 rooms at the show? biggrin.gif
NAIM101 is offline
Old 10-20-2013, 07:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Please provide an example that illustrate your exceptional claim above, with some good reliable, bias controlled listening tests to back it up.
I guess that depends on how you define the words. They are obviously rather critical because if they don't effectively interface the equpment - the results are pretty obvious - no sound at all!
It sounds like you've used this pitch many times with profitable results. If we wished to recommend the store you appear to work at, what is its name and location?
What do you mean by "help"?
arnyk is offline
Old 10-20-2013, 07:17 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Please explain to me why we should be interested in rooms at hi fi shows?
It is well known that the sound quality of audio systems particularly their speakers is profoundly affected by the rooms they play in.
Since few if any of us live in hotel rooms, why would the sound of stereo gear playing in hotel rooms matter to us?
arnyk is offline
Old 10-20-2013, 11:35 PM
I don't sell cables and I don't get them from home depot. I own mostly Kimber Kable AG interconnect and Kimber Kable 8tc and and 8AG speaker cables. If sound like you are a car audio guy.
Old 10-21-2013, 03:09 AM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
NAIM101 is offline
Old 10-21-2013, 03:10 AM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Speakers by itself still plays a big part in the sound coming from the rooms.
NAIM101 is offline
Old 10-21-2013, 07:05 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Once the speakers being considered reach certain performance levels that are not uncommon among modern high performance speakers, that big part gets to be a lot the same among different speakers.
Level matched blind speaker comparisons can surprize many.
Last time I went to a high end hi fi show, I was dismayed by how many of the speakers being offered were much alike - 2 way speakers based on a 5-6 inch woofer and a dome tweeter. If the drivers and crossover are good, these speakers are not going to sound worlds apart different. There were more than a few samples that seemed to have dodgy crossovers.
I think you might be surprised if you ever actually moved speakers around in a room, or moved them to other rooms.
Notice, you can't do this by reading articles on the internet, you actually have to get out of your chair and do a little manual labor! ;-)
Relevant articles of a educational and factual nature:
http://www.avsforum.com/t/1325085/blind-testing-speakers-8o
with Linkwitz' response:
http://linkwitzlab.com/frontiers_6.htm#Z%20-
Transmaniacon likes this.
arnyk is offline
Old 10-21-2013, 07:58 AM
audiomagnate's Avatar
...Seems like this thread is spinning into a battle between system eq and room acoustics.
Taking either side is like flunking an IQ test, because you need both to have really good SQ no matter what your room is or how good your speakers are...
Yep.
I hear that a lot, and it just doesn't make sense to me. Hotel rooms have walls, ceilings, carpet and furniture, just like listening rooms. What's the difference? There are good and bad sounding hotel rooms, just as there are good and bad sounding listening rooms. If the vendor really cares about how his product is going to sound at a show he will take the time to optimize the room and speaker placement, or insist on another room if it's a real stinker. Horrible sounding rooms are the exception at most shows, mediocre sounding speakers are the rule. If you think auditioning speakers at shows is of little or no value, how DO you determine how a given speaker sounds? Do you make your decisions based on what you read on line or in the glossy mags? Does your local retailer have every speaker you are interested in stock and on display in an optimized room in the perfect location? Or are you so wealthy that you simply have them all brought into your room a pair at a time for your personal evaluation. I evaluate speakers by going to shows and listening to them. Pretty weird, huh?
audiomagnate is offline
