Active studio monitors in a home 2 channel system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-22-2013, 08:16 PM - Thread Starter
rntlee's Avatar
I have an opportunity to buy a pair of jbl lsr6328p monitors for $1000...would be difficult to incorporate them into a home setup?
rntlee is offline
post #2 of 12 Old 08-22-2013, 08:53 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Nice speakers, accurate near field monitors. If this is what you are after,, no issues in a 2CH home system
stevensctt is offline
post #3 of 12 Old 08-23-2013, 11:21 AM
Wayne Highwood's Avatar
Liked: 43
They're probably easier to incorporate into your listening room than many speakers, actually. I would be more concerned with having appropriately dynamic and capable subwoofage.
Great price, assuming they're new/minty.
Wayne Highwood is offline
post #4 of 12 Old 08-23-2013, 02:37 PM - Thread Starter
rntlee's Avatar
I don't have a source with xlr outs...is it alright if I were to use xlr to rca adapters for these speakers? I think I'll buy them anyway, even if I don't use them I don't think theres any risk involved at that price. They're used but in mint condition.
rntlee is offline
post #5 of 12 Old 08-23-2013, 04:40 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
I've used XLR to RCA adapters, they're fine. Good buy on the speakers.
post #6 of 12 Old 08-26-2013, 02:58 PM
Xyrium's Avatar
Quoted: 21 Post(s)
Very nice indeed. The 6000 series are sweet. Just remember, if you're distance is greater than the average nearfield, your soundstage and HF may begin to diminish. I have only heard these within 5 ft of my ears, but I believe they come with room correction software that may include a distance setting.
Shame you can't find a preamp to use the differential inputs. HOwever, by cutting one of the diff legs you can still use RCAs (2 conductors instead of 3).
That's an amazing price, especially if new.
Xyrium is offline
post #7 of 12 Old 08-26-2013, 03:51 PM - Thread Starter
rntlee's Avatar
I have them working right now with 1/4"---->rca adapters. The jbl's have an xlr connection that is also 1/4" compatible. They make for one sweet sounding 2 channel setup. I'm going to buy the room correction kit but according to the manual there a setting to boost hf for flat rooms...just need some time to play with the settings on the back. These things will rock...and super clean at high spl. Was going to look for the matching sub, but after playing with them not sure if i really need it.
rntlee is offline
post #8 of 12 Old 08-27-2013, 07:34 AM
Liked: 43
Yeah, baby! Respect the dynamic range of the music! Too many domestic type speakers fail in that regard. Glad you're liking them.
post #9 of 12 Old 08-28-2013, 05:49 PM
Currawong's Avatar
Most active speakers seem to be for pro audio use, since they can plug them straight into a mixing console, but given the quality of the mostly Class A/B amps in them they can be quite good in my experience. I don't listen loud though, ie: I'm not trying to re-create a concert hall in my living room, so any lack of dynamics at louder volumes doesn't bother me. I also don't use a sub.
Currawong is offline
post #10 of 12 Old 08-28-2013, 06:24 PM - Thread Starter
rntlee's Avatar
No lack of dynamics in these ones...they're bi-amped with 250w for the LF section and 125w for the HF section.
rntlee is offline
post #11 of 12 Old 08-28-2013, 06:27 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Spec sheet says: Maximum SPL (80 Hz - 20 kHz) : >108 dB SPL / 1m
A pair will do reference level at typical listening distances.
arnyk is offline
post #12 of 12 Old 08-31-2013, 10:01 AM - Thread Starter
rntlee's Avatar
Well, these are definitely keepers and are now replacing my Paradigm monitor 7's and sub combo in my 2 channel setup. The Paradigms sounded pretty good to with a sub for reinforcement, but these JBL's outclass them by a good margin...and that's without a sub! Highly recommend these if you can snag a pair for the right money.
rntlee is offline
Reply 2-Channel Audio
