Newbie, looking for cheap entry into excellent sound quality - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 08-26-2013, 08:22 PM - Thread Starter
PipCount's Avatar
Hi. I just joined up in order to post, and am fairly ignorant in many aspects of hi-fi stereo equipment, so bear with me.
I'd like some suggestions for starting out. My main objective is to listen to albums (CD), and have it sound awesome.
I currently have a Philips DFR 1500 CD/DVD/Surround Sound Receiver, and some small RCA speakers (a 5.1 set); this was all given to me by a friend, which is awesome, because it does sound better then the computer speakers I was using. However, it doesn't sound that good when listening to music. The subwoofer seems decent, and electronic/rap/stoner metal can sound pretty good. But Jazz, or any rock with higher melody sounds flat/washed out. (In addition, the built in CD player doesn't work, neither does the remote, or the 2 rear channels on the receiver).
I'd like to upgrade.
My speaker budget is $100, so I'm starting by looking for some decent used speakers (thrifting or craigslist), but I have no idea what I should really be looking for. Are there certain brands to look for that are more likely to turn up used?
The stereo is in a room (kitchen/living area) that's about 16'x20', what size speakers are needed to sound good?
Should I also look for a different receiver? All I really want is Left-Right-(sub), and that seems to work on my current receiver. Maybe I could get away with dropping $200 on a receiver and speakers...
Any advice?
Conan
PipCount is offline
post #2 of 32 Old 08-26-2013, 08:34 PM
Bond 007's Avatar
Quoted: 2621 Post(s)
Liked: 2083
Welcome to AVS.
"Cheap" and "excellent sound quality" will never be had together. Most people here have more than $100 in their remote control. Your best bet would be Craigslist imo. You wont be able to afford any decent towers so look for bookshelf speakers.
Licence to Kill
Bond 007 is online now
post #3 of 32 Old 08-26-2013, 08:57 PM - Thread Starter
PipCount's Avatar
Originally Posted by Bond 007 View Post
Welcome to AVS.
Thanks. Yeah, I realize from browsing the forums that you guys are in a different league than me.
Should I aim for a certain size woofer in order to pump up the jams in my living room? Any brands in wide circulation that are a pretty safe bet when buying used?
PipCount is offline
post #4 of 32 Old 08-26-2013, 09:03 PM
Bond 007's Avatar
Liked: 2083
I honestly dont know. For that kind of money its going to be really slim pickings. Klipsch, Polk, Pioneer, Bic are all good brands. If you have a sub I wouldnt worry about woofer size. Just try to get quality speakers.
Licence to Kill
post #5 of 32 Old 08-26-2013, 09:04 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Since you won't have a sub, 5" to 6.5" woofers are the best bet. They go low enough.
You might find JBL, Klipsch, NHT, Polk - and depending on the model could be a good deal. Really, I think use luck of the draw is where you are at. Goodwill/salvation army stores sometimes you can get lucky at as well. I would avoid the big no-name towers that you sometimes find there.
lespurgeon is offline
post #6 of 32 Old 08-27-2013, 02:29 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Any advice?
Try looking at the "Famous designer" speakers from Pioneer:
http://news.cnet.com/8301-13645_3-57490890-47/mission-impossible-design-great-sounding-affordable-speakers/
More specifically:
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG
$80 a pair!
Another alternative:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-652
arnyk is offline
post #7 of 32 Old 08-27-2013, 03:48 AM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 18969
fwiw, if you live near a fry's electronics store the pioneer bs-22's go on sale quite often for $77 a pair or you can take a look at another good bargain in the infinity p163's which are on sale now for $99 .if you like to listen to music loud the infinity's are more efficient and will play louder.
PipCount likes this.
i'm so laid back,i'm laid out
smasher50 is offline
post #8 of 32 Old 08-27-2013, 08:47 AM - Thread Starter
PipCount's Avatar
Thank you! The BS-22s have some glowing reviews! I do like louder music on occasion, and the p163s are on sale for $90 at Crutchfield; I just may pull the trigger. How can I tell if speakers will work with my receiver?
PipCount is offline
post #9 of 32 Old 08-27-2013, 11:03 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Any speakers will work with your receiver, but one issue with the excellent-sounding Pioneer speakers is their low sensitivity.
This can mean that a lower-powered receiver will not have enough power for them for higher volume levels.
commsysman is offline
post #10 of 32 Old 08-27-2013, 12:13 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
You might find something nice in thrift store. I recently donated two speaker systems locally to the Goodwill store. One was a 90's vintage Boston Acoustics Sub/Sat 6 system that sounded pretty good for what it was. The other was a pair of Vifa driven MTM type systems with a pair of 8" woofers surrounding a 1" tweeter. They weighed in at 70 lbs each and my wife made me get rid of them. They sounded great but didn't meet the basic eye appeal requirements of my better half. Whoever bought those certainly got bargains. The Pioneer bookshelves that ArnyK recommended above have good reviews.
FMW is offline
post #11 of 32 Old 08-27-2013, 12:41 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The Philips DFR 1500 is so old and limited that the user's manual doesn't even list the power ratings. However, based on the heatsink and the UL power rating on the back panel, I'd guess maybe 100 wpc.
It shouldn't be in trouble with the little Pioneer speakers.
arnyk is offline
post #12 of 32 Old 08-27-2013, 12:53 PM - Thread Starter
PipCount's Avatar
Ordered the P163s. Seemed like a good deal at $90, and didn't know how long the sale would last.
Appreciate the input from everybody; and I'm still armed with more knowledge in case I do stumble on some good thrift store speakers.
PipCount is offline
post #13 of 32 Old 08-27-2013, 01:16 PM
FMW
FMW's Avatar
Liked: 1686
Hope you understand the $90 is for one speaker, not a pair.
FMW is offline
post #14 of 32 Old 08-27-2013, 01:53 PM
Bond 007's Avatar
Liked: 2083
lol Seriously?
Licence to Kill
post #15 of 32 Old 08-27-2013, 02:05 PM
nturchin's Avatar
Can the mods please move this post to the 1 Channel Audio forum?
beaveav and PipCount like this.
nturchin is offline
post #16 of 32 Old 08-27-2013, 03:09 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
nturchin doesn't always post on AVS, but when he does, he prefers to drink Dos Equis while doing it. tongue.gif
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #17 of 32 Old 08-27-2013, 03:11 PM
BassThatHz's Avatar
Quoted: 2346 Post(s)
Liked: 2108
If you can double your budget to $200 per speaker, and are handy with making your own speakers, you could have two of these:
http://www.diysoundgroup.com/waveguide-speaker-kits/other/bwaslo-15-kit.html
Their sound quality is on par with B&W 802's, I'm not joking.
www.stereophile.com/floorloudspeakers/1205bw‎
That's what I run. (I actually run 7 of them... It's a work-in-progress.)
The black theater paint I put on my walls was: $500, the carpet that my speakers are sitting on is: $2000. My subwoofers cost me $13000.
It sure can add up quick.
BassThatHz is offline
post #18 of 32 Old 08-27-2013, 05:56 PM
FMW
FMW's Avatar
Liked: 1686
Stay thirsty, my friend.
FMW is offline
post #19 of 32 Old 08-28-2013, 11:51 AM - Thread Starter
PipCount's Avatar
Seriously! I'll keep it polite and not type what I'm really thinking. And I just got an update that the order already shipped!
Who ever heard of selling a single bookshelf speaker? Though it clearly says 89.99 each, and I missed it!
Looks like it's $10 to return to Crutchfield. So now my budget is $90...
Maybe I'll try selling the small RCA surround speakers and some boardgames to get another $90 and order the other p163. Though a pair of BS-22s is $50 cheaper.
As for playing loudly: will the BS-22s (paired with my sub) handle loud volumes. I don't play music obnoxiously loud, but on occasion I'll have it loud enough where you'd have trouble having a conversation in the same room as the speakers.
And my receiver puts out 70W per channel, enough for BS-22s.
PipCount is offline
post #20 of 32 Old 08-28-2013, 01:10 PM - Thread Starter
PipCount's Avatar
And my receiver puts out 70W per channel, enough for BS-22s?
Meant that as a question, is 70w enough for BS22s thanks?
PipCount is offline
post #21 of 32 Old 08-28-2013, 02:13 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Yes.
arnyk is offline
post #22 of 32 Old 08-28-2013, 02:20 PM
Bond 007's Avatar
Liked: 2083
Originally Posted by arnyk View Post
Yes.
Agreed
Licence to Kill
post #23 of 32 Old 08-28-2013, 04:00 PM - Thread Starter
PipCount's Avatar
So, a local Craigslist went up with a pair of Polk RT55s, unnamed pair of Definitive bookshelf speakers, a polk subwoofer, and an Onkyo TX SR506 receiver.
I can't find many newer posts about RT55 speakers, but the ones from a decade ago make them out to be good speakers. It seems that I could come close to breaking even if the RT55s work out by re-selling the Definitives and my current 5.1 system (keeping the better subwoofer). Or, more likely, I'll be out ~$50 for a pair of RT55s and an upgrade to my receiver.
Does anyone have experience with RT55s? Do they compare to the aforementioned speakers? Am I better off getting something newer?
Thanks for all the help thus far.
PipCount is offline
post #24 of 32 Old 08-28-2013, 09:55 PM
alanhenson's Avatar
Quoted: 32 Post(s)
The good thing is you're not spoiled like us so you probably don't even know what excellent sounds like. My 8 year old nephew thinks Ryans steakhouse its the greatest did ever created. I wish sometimes I was in your position. Buy some decentd condition used gear and you will likely be thrilled. Don't spend a lot on cables. Won't make a bit of difference.
alanhenson is offline
post #25 of 32 Old 08-29-2013, 03:25 AM
FMW
FMW's Avatar
Liked: 1686
Sorry to have been the bearer of bad news. I think if you can get the funds for the second speaker you will enjoy them.
FMW is offline
post #26 of 32 Old 08-30-2013, 11:34 AM
rongon's Avatar
Since everybody buys speakers for 5.1 or 7.1 these days, and the "5" and "7" are odd numbers, it's often necessary to buy single speakers to complete a surround setup. It's a surround thing, I wouldn't understand, being a 2-channel kinda guy...
Hopelessly addicted to this stuff.
rongon is offline
post #27 of 32 Old 08-30-2013, 11:38 AM
rongon's Avatar
Seriously? Wow.
Thanks for the comparison, since I'm well acquainted with the sound of B&W 801, 802, etc.
I've been on a quest to find good sounding high-sensitivity speakers for my little weenie tube amp. I've been trying to put together a 10" plus horn tweeter setup that competes with my Snell Type C's. I find the horns sound more forward, maybe not as 'sweet' as the old Snells. But maybe those SEOS based speakers are smoother sounding in the upper mids? Maybe...
rongon is offline
post #28 of 32 Old 08-30-2013, 11:53 AM
rongon's Avatar
Oh, by the way... Re: the OP, if you know what you're looking for, craigslist can be a good source of decent gear for cheap. They're not my cup of tea, but there are a lot of Polk and Klipsch speakers out there that go for low prices. If you have the room for a pair of floorstanding Klipsch from the KG series, these don't fetch much money. They are big. They sound pretty good, though, and will go crazy loud with any power at all. Sometimes you can find older Klipsch Reference series speakers for low money (RF or RB models). Those are better, imo.
Good luck. I got into tube gear back in the early 1980s because that stuff gave me good sound for little money (back then, not now!). There are always audio bargains to be had. The problem is finding what is undervalued at the moment.
rongon is offline
post #29 of 32 Old 09-02-2013, 05:31 AM
Bond 007's Avatar
Liked: 2083
post #30 of 32 Old 09-02-2013, 07:35 AM - Thread Starter
PipCount's Avatar
Thanks again everyone.
I returned the P163 to Crutchfield (big kudos to them, no questions asked, flat $10 fee for return postage), and this weekend picked up some speakers on Craigslist: a pristine pair of Polk RT55s (with stands) and a 303b sub. They sound awesome!
Also form that craigslist deal were a pair of Definitve Bi-Polar 1 bookshelf speakers and a Paradigm CC-150. Hopefully I can re-sell these (I listed them $50 for the BP-1s, $30 for the center channel), and I'll have upgraded my speakers "for a song."
PipCount is offline
Reply 2-Channel Audio
