Replacing Bose 901 Series IV with.. ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-29-2013, 04:20 AM - Thread Starter
svhovater's Avatar
hi folks
I've a pair of 901's that have been singing for 25 years now.. Love them. But - I'm seeing all these smaller systems that don't have quite the same real estate requirements..
So - the question is, what compares to the 901's, and is wall-mountable? I'm presuming that a subwoofer will be part of the configuration.
And yes, I've suspended my 901's in the past - we don't have a suitable space where this can be done now. frown.gif
I've looked at - but not heard - the AcoustiMass 5's - also Bose. I don't really want to upgrade my receiver as well.
thoughts?
svhovater is offline
post #2 of 11 Old 08-29-2013, 07:54 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
If you love those Bose speakers, with their bloated, highly colored sound qualities, be sure to avoid any speakers that accurately reproduce sound.
Better stick with Bose all the way.
commsysman is offline
post #3 of 11 Old 08-29-2013, 08:37 AM - Thread Starter
svhovater's Avatar
I'm open to suggestions..
what would you recommend?
post #4 of 11 Old 08-29-2013, 08:53 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
+1
arnyk is offline
post #5 of 11 Old 08-29-2013, 11:31 AM
someoledude's Avatar
Quoted: 14 Post(s)
So you are looking for something to wall mount for primarily music? Is this due to a space/aesthetic restriction or just what you have traditionally done? Would you be open to a subwoofer?
someoledude is offline
post #6 of 11 Old 08-30-2013, 03:02 AM - Thread Starter
svhovater's Avatar
Hi -
Thanks - this will be for music only, and primarily to save floor space (new house).
Subwoofer - I completely expect, and don't have a problem with.
cheers
Steve
post #7 of 11 Old 08-30-2013, 05:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by svhovater View Post
Hi -
My problem is that I have a fairly close association with someone who is a Bose 901 aficionado, and to this day he can't really be happy with a conventional loudspeaker.
I view this as a risky experiement, so I will recommend a 2.1 system that is fairly inexpensive but actually sounds very good:
A pair of Infinity Primus P163 and an Acoustech PL200 subwoofer. Add a good AVR and see if you can still stand to listen to conventional speakers.
arnyk is offline
post #8 of 11 Old 08-30-2013, 06:08 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
I had 901's and had them suspended. Every member in my home banged into them, a lot of head aches. As some else on this forum said, I bet they were good for Head Banger Music. I am embarrassed to say this but, I liked them. I'll go hide now..
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #9 of 11 Old 08-30-2013, 06:22 AM
ctsteve's Avatar
I enjoyed my 901's for 20 years as well before replacing with Martin Logans.
For something small enough to be wall mountable, I think the Mirage OmniSats have always held their own. Better sound than the Bose cubes, but the omnidirectional sound has similar characteristics as 901's. Paired with a beefy sub and crossed over high enough, they could be an option. They are also very forgiving of placement. I use them for surrounds in my theater and they work well even mounted very high. And you won't bump your head on them like 901's.
ctsteve is offline
post #10 of 11 Old 08-30-2013, 12:28 PM
Gizmologist's Avatar
Liked: 31
Lots of folks simply used the pedestals for 901s and quite successfully.
Gizmologist is offline
post #11 of 11 Old 08-31-2013, 09:13 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I've always wondered if a good set of bipoles might not give some of the 901 fans the more diffuse soundfield they are looking, only with better drivers and better frequency response output. smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Reply 2-Channel Audio
