The 2 channel question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-03-2013, 07:32 PM - Thread Starter
MOTOSCUBA's Avatar
Are there any home theatre receivers out there that will preamp output to an external system, all the sources connected to it such as Sonos or resident to it such as FM or AirPlay? My Denon 2313 will only preamp output from an external analog input. Useless.
MOTOSCUBA is offline
post #2 of 4 Old 09-04-2013, 05:22 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Yes, but you have to move up to far more expensive products. In my book the 2313 lacks preamp outputs in the classic sense that are used to power the main speakers with larger amps. All it seems to have is a L&R pair that are designed for a second pair of speakers, presumably in a different room.
This is the back panel of a Denon 3313:
Note that it has a complete set of preamp outs that have the same signals as are passed to the internal amps for the usual run of speakers that one uses in the same room as the AVR.
arnyk is offline
post #3 of 4 Old 09-04-2013, 05:57 AM - Thread Starter
MOTOSCUBA's Avatar
I think you missed the main point if my question. Sorry I was not clear. The 2313 has preamp outputs but sources internal to the reveiver ie airplay, fm, etc will not pass thru to zone 2. And this is also true for the 3313. You can play music from your iPhone thru airplay on the main speakers, but not on zone 2. If you notice on your 3313 pic submission directly above the preamp out is a series of external analog inputs for the preamp outs. You are restricted to these inputs for Zone 2.
Please comment.
post #4 of 4 Old 09-04-2013, 08:54 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Please comment.
I think I read in another thread that zone 2 outputs do pick up internal digital sources in some of the new models that just came out.
All of the user current and recent past manuals are free downloads...
arnyk is offline
Reply 2-Channel Audio
