Looking to replace a peachtree audio decco 65 (unhappy with the sound). - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-21-2013, 03:52 PM - Thread Starter
touser's Avatar
I picked up a peachtree decco 65 a few months ago for use on my desk along with a pair of paradigm mini monitors. Unfortunately the sound of the peachtree just isn't for me, i'm far too used to the sound of my Dynaudio Audience 52 SE's paired with pioneer SC-65. Does anyone know of any desktop sized amplifiers (USB is preferred but I can use an additional usb sound card if necessary) that will produce a sound more similar to the SC-65? The SC-65 is way too large for my desk. Thanks!
touser is offline
post #2 of 11 Old 09-21-2013, 05:21 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3081
Did you use bass management with your Pioneer receiver? That would probably be the main reason for the difference in sound quality
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 11 Old 09-21-2013, 05:49 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
That and room calibration would be the only reasons.
FMW is offline
post #4 of 11 Old 09-21-2013, 06:04 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
or the speakers.
lovinthehd is offline
post #5 of 11 Old 09-21-2013, 06:06 PM - Thread Starter
touser's Avatar
Thanks for the replies. I do not use bass management on the pioneer. I'm not technical enough to describe the sound difference very well but they both produce distinctly different sounds. The peachtree sounds extremely flat, almost muffled in comparison to the pioneer. It just sounds bad to me.
touser is offline
post #6 of 11 Old 09-21-2013, 06:21 PM
citizen arcane's Avatar
Quoted: 284 Post(s)
Liked: 8328
Originally Posted by lovinthehd View Post
or the speakers.
Yup. The poster never mentioned swapping out the amps with the Paradigms, just two different set ups
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #7 of 11 Old 09-21-2013, 06:42 PM
lovinthehd's Avatar
Liked: 4775
Why is this not a result of the speakers? Or are the speakers identical somehow? How about the placement of the speakers? The room?
post #8 of 11 Old 09-22-2013, 08:05 AM
FMW
FMW's Avatar
Liked: 1681
I assumed he tested to amps in the same system. If they are different systems then the issue is settled. For the OP. If you play the receiver in pure direct it will sound exactly the same as the integrated amp does in the same system. A calibrated receiver will sound different and a different system........well enough said.
FMW is offline
post #9 of 11 Old 09-22-2013, 10:06 AM
syd123's Avatar
Quoted: 57 Post(s)
Liked: 59
If you didn't use any tone controls, bass management or room correction w/ the Pioneer, then there is NO reason why the Peachtree should sound any different from the Pioneer unless something is wrong with it. Usually, however, a problem w/ a component is generally SO apparent that there would be no question about this. ..Like it won't turn on, or tons of hum, horribly garbled sound, one channel completely out, ...that sort of thing. ..So if you're not hearing something as obvious as this, then it unlikely there is a problem w/ the Peachtree..
Is it possible you have the speakers wired out of phase? ..I'd recheck your wiring first and foremost. If not that, then the next most likely culprit is something called expectation-bias, and that problem originates not from the component, but rather in our own minds smile.gif ..Is it possible you read an unfavorable review or forum post regarding the Peachtree that has given you a bit of buyer's remorse?
McIntosh MA6600 Integrated amp (for 2-ch) | Onkyo TX-NR1030 AVR (TV/ Movies) | Paradigm Sig S8 v2's (front) | Paradigm Prestige 55C (Center) | Boston Acoustics Bravo 20 speakers (rear) | 2010 Technics SL-1200mk2 Turntable w/ AudioTechnica 440mla cartridge | Mac Mini Music Server | Emotiva XDA-2 DAC | Logitech Touch SB | Samsung PN58B860 Plasma TV
syd123 is offline
post #10 of 11 Old 09-26-2013, 05:29 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest that you look at the Rega Brio R amplifier.
IMO it will sound much better than the amplifier you have, and it is quite compact in size.
Of course the Dynaudio speakers are always going to sound 1000% better than the baby Paradigm speakers, which I do not care for.
Actually, you could just get a pair of Audioengine A2 powered speakers for $200.
I guarantee that they will sound very nice.
I use them with my computer, and the sound is quite good.
They don't sound as good as my $25K system with Vandersteen Treo speakers, but then I have heard few systems that even come close to it (at ANY price).
commsysman is offline
post #11 of 11 Old 09-27-2013, 05:15 PM
shawndo's Avatar
Quoted: 49 Post(s)
Liked: 29
Quick question. Why was it that the OP thought the sound difference was due to the amp and not the speakers?
shawndo is offline
Reply 2-Channel Audio
