Newb ventures into hi-fi and vinyl - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 12-26-2013, 02:17 PM
A9X-308's Avatar
Quoted: 1304 Post(s)
Liked: 965
Originally Posted by citizen arcane View Post
I'm a bare wire kinda guy cool.gif even always using 12 ga. Just wanted to let the OP know there were other options, including pins, lugs and these discussed......
I'd rather do crimped lugs, and if the knobs come all the way off, I'd use ring (banjo) lugs. If they don't, spades. No need for anything fancy; quality copper crimp lugs are available for little at electrical supply houses. Assumes of course that you have, or can borrow the correct crimper.
A9X-308 is offline
post #32 of 32 Old 12-26-2013, 02:28 PM
kraut's Avatar
Liked: 61
I'm a bare wire kinda guy even always using 12 ga. Just wanted to let the OP know there were other options, including pins, lugs and these discussed..
You are right of course. Sometimes one develops tunnel vision based on habits...
kraut is offline
Reply 2-Channel Audio
