Which turntable to choose, Music Hall mmf2.2 or Pro-ject Debut Carbon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2014, 05:59 AM - Thread Starter
PLTurbo's Avatar
Hello everyone,
I got to replace my old turntable and my choice stopped at either Music Hall mmf2.2 or Pro-ject Debut Carbon.
I read great review about the Pro-ject Debut Carbon, however I mainly listening at some Rock, Alternative and some Country music. Some of the review I read complains about the lack of kick when listening at this music type.
My new turntable will be connect to my Stereo Rotel RC-1070 pre amp with power amp RB-1070.
Do you guys have any advise concerning those two turntable ?
Thank you
HC2040 with Silver Ticket 110" white matl screen.
Pionner VSX-1130
2x Polk T600,2x Polk T300, Polk CSIA4, S/W BIC H-100
PLTurbo is offline
post #2 of 5 Old 01-29-2014, 01:34 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
This isn't really what you want to hear, but there isn't a lot to choose between them. Partisans can give you specious arguments for one or the other, but you'd do just as well to flip a coin. If it helps, you can't go wrong either way.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 5 Old 01-30-2014, 06:18 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
And Pro-Ject makes the turntables for Music Hall, so there is likely to more in common than;) different!
jdcrox is offline
post #4 of 5 Old 01-30-2014, 09:44 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Right. Same basic design, and made in the same factory.
mcnarus is offline
post #5 of 5 Old 01-31-2014, 02:35 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The turntables are quite similar, but I am partial to the Music Hall version.
Any sonic differences will be between the cartridges that come with them, which are pretty basic.
You can spend $200-300 for a better cartridge and that will be a major sonic upgrade for either one.
A Musical Fidelity V90 LPS phono stage will also be a big improvement.
commsysman is offline
Reply 2-Channel Audio
