Which sounds better - 24/192 or 32/192? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 02-02-2014, 08:54 AM - Thread Starter
southleft's Avatar
Quoted: 32 Post(s)
Liked: 24
We have our CD collection ripped to a hard drive in 16/44 .wav format and it works fine. With access to larger hard drives we now want to re-rip for better sound quality. Has anyone here listened extensively to 24/192 vs. 32/192 ? Is it worth ripping in 32/192? Thanks for your thoughts on this.
southleft is offline
post #2 of 22 Old 02-02-2014, 10:26 AM
Stanton's Avatar
Quoted: 1549 Post(s)
Liked: 796
You sort of answered your own question. CD's (Redbook) are by definition 16/44, so ripping them to anything else is overkill (or a waste of time). If you started with a higher resolution source, then you can talk about storing in a higher resolution format.
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #3 of 22 Old 02-02-2014, 10:27 AM
mjd420nova's Avatar
Re-rip?? What's the original media?? Further compression schemes cannot replace or reproduce elements that were eliminated during the first conversion to digital. Increasing the bit sample 16/24/32 from a lower number to a higher number will not increase the fidelity, the same with the bandwidth. Ideally, the orignal digital copy of the analog media should be done at the highest bandwidth and highest sample rate. Selected schemes, once burned to DVD/CD or stored on removable media may not be playable on other units. The CD industry settled for the .WAV format, 96k bw and 16 bits. Compression by any means put further limits on media content, regardless of the "lossless" claims.
mjd420nova is offline
post #4 of 22 Old 02-03-2014, 10:03 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
To help your understanding of this issue, here is what upsamplers do. When upsampling 16 bits to > 16 bits the additional bits are first set to zero (0). When increasing the sample rate, the additional samples are first set to zero (0).
in short, upsampling is a way to make it cost you more to store your songs, by padding them with zeros.
arnyk is offline
post #5 of 22 Old 02-03-2014, 05:29 PM
wrat's Avatar
but what if they are magic zeros,,,,,
wrat is offline
post #6 of 22 Old 02-03-2014, 07:17 PM
SAM64's Avatar
Liked: 78
How do you get 96K of bandwidth out of a 44.1K sample rate?
SAM64 is offline
post #7 of 22 Old 02-04-2014, 08:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Conflate bandwidth and bitrate for lossy compressed files?
arnyk is offline
post #8 of 22 Old 02-05-2014, 03:56 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
The very best modern audio DACs have between 20 and 21 bits of resolution. 24 bits in recording is already overkill.
Of cause if you are ripping CD, it is only 16/44.1, and there is nothing you can do about it. Always keep all digital files in their ORIGINAL format - in case of CD it is 16/44.1.
ap1 is offline
post #9 of 22 Old 02-05-2014, 07:31 PM
Iostream's Avatar
Quoted: 34 Post(s)
24 bits in recording is certainly not overkill, But you confuse recording with output. I wouldn't dare record or produce in anything less than 24 bits, There is a lot going on when you are recording and mixing, the extra headroom in the dynamic range is particularly helpful in keeping the noise floor out of the signal. By the time you have mastered, this is no longer an issue, and printing to 16 bit is no loss of quality at all. Most of the noise is removed in mastering with a gate. The exception is when you might actually need over 93dB of dynamic range, though this would be incredibly rare in music.
To answer the original posters question, there is no benefit in upsampling a CD. 16/44.1 lossless is great.
JD NC likes this.
Mastering and 2 Channel: Wavelab 9/Bluesound Node/Pro-ject RPM 5.1 SE -> McIntosh C47 -> McIntosh MC452 -> Focal Sopra No 2 and REL S5/SHO (switchable)
Mixing and desktop: Cubase/Squeezebox -> Oppo HA-1 -> Rotel RB-1080 -> B&W N805 and REL S2
Theater: Oppo 103d -> Marantz SR7009 -> Martin Logan Motion 4/8 7.1 with REL S5/SHO
Living Room: Marantz SR5009 -> Rotel RB-993 -> B&W N804/HTM1 Rythmik F12SE
Iostream is offline
post #10 of 22 Old 02-06-2014, 05:36 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Originally Posted by Iostream View Post
24 bits in recording is certainly not overkill...
The Brownian motion of air at STP makes a noise just below 0 dB SPL. 24 bits gets you 144 dB of dynamic range above that - just about right for making:
(1) Nice recordings of natural music with the Brownian Motion of air rendered with 6 bit resolution.
(2) Nice recordings of sounds that it takes high explosives to create with a noise floor at 0 dB SPL.
(3) Unclipped recordings of thermonuclear blasts miced at a few feet with a normal quiet room's noise floor.
That would appear to be personal angst operating.
IME mixing is always based on tracking and your raw tracks are what they are and ever will be and perfectly knowable and defined.
I don't know how a person can call himself a professional recordist if he can't set levels within 20 dB. : -)
One of the most telling events of history was the roll out of SACD and DVD-A around Y2K. It turns out that something like half of all releases had masters with 16 bits or less resolution in their provenance. Yet, not even on high end audio reviewer that I have heard of or has been pointed out to me was able to pinpoint even just one recording as being based on a substandard master.
In the end the whistle was blown by geeks with FFTs.
http://xiph.org/~xiphmont/demo/neil-young.html
A typical example of a so called high rez recording that was obviously upsampled from a low rez master:
http://www.whatsbestforum.com/showthread.php?3220-When-is-Hi-Res-not-really-Hi-Res/page16
arnyk is offline
post #11 of 22 Old 02-06-2014, 06:26 AM
Iostream's Avatar
Quoted: 34 Post(s)
Clearly written by someone who doesn't actually record/mix. Let's assume you have a moderate actual noise floor from the recording of 10db, Not uncommon depending on what you are recording. Electronic noise, room noise, etc. Now you have to actually mix the tracks, you are merging tracks and going through EQ at the very least. 18db is considered safe headroom for mixing in most situations. This assumes you are leaving no headroom for mastering, which is unwise, common practice is to leave 3-6db after the mix before you master. You have just lost almost 5 bits of resolution. to noise and mixing headroom. Realistically you would have 72db of dynamic range available with 5 bits dedicated to noise and mix headroom. This is not enough. Now, realistically 20 bits would probably be fine in most situations, but 20 is not an option with most DAWs or recording interfaces, so 24 is your next step from 16.
Again, there is no reason to deliver a 24 bit track as a final product. The reason it is done is hype, "this is what it was recorded/mixed/mastered in" . I have complete faith in my dithered output because I have compared the 24 bit version to the 16 bit version every time. That said, sample rate conversion is less straight forward, and laziness prevails, so why bother to dither to 16/96 instead of just shipping 24/96?
speavler likes this.
Iostream is offline
post #12 of 22 Old 02-06-2014, 12:49 PM
SAM64's Avatar
Liked: 78
TV audio is currently recorded at 24bit, 48K.
On playback it is compressed to approximately a 6dB dynamic range for transmission....because this is, sadly, what the consumer wants.
SAM64 is offline
post #13 of 22 Old 02-06-2014, 01:44 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
I've recorded thousands of groups, and 100s of live events, and keep on doing it. I record band and choir festivals at regional and state level events and also mix religious events in mid-sized venues at least several events every week end.
I can do this science experiment at wlll, and the numbers you throw around show exactly what your experience and knowlege is.
First off the self noise of the typical high quality microphone used in recording runs around the equivalent of 18 dB SPL. There are a few mics that do better than that and I've owned them and used them. This gets you to part two of the real world - the ambient noise in a room with an audience runs between 30 and 45 dB SPL. Take out the audience and you still have the self-noise of the musicans, which in large numbers (50-100) are like a small audience - a few dB better.
The 18 dB headroom was presumably used while recording the tracks and therefore doesn't have to be put in again while you are mixing. No net loss.
if you look at actual commercial recordings, they have from 55 to 75 dB dynamic range with a few exceptions running higher.
arnyk is offline
post #14 of 22 Old 02-06-2014, 01:49 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Don't make the mistake of believing that just because the equipment is capable of working with 24 bits that the recordings they make, even in raw state are anywhere near the 144 dB dynamic range implied by 24 bits.
It's had to buy converters that don't have 24 bits on the front panel, but most them have converters that are capable of 100-110- at best 118 dB.
However, don't make the mistake of looking at the signals coming out of the mics and mixer, they are invariably worse, often far worse.
arnyk is offline
post #15 of 22 Old 02-06-2014, 01:58 PM
SAM64's Avatar
Liked: 78
Don't make the mistake of attempting to be an authority on everything wink.gif
sivadselim likes this.
SAM64 is offline
post #16 of 22 Old 02-06-2014, 02:15 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Too late.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #17 of 22 Old 02-06-2014, 04:39 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Originally Posted by Ratman View Post
Too late.
It would obviously not be a good thing for your egos if I started posting about my actual area of expertise which does not have to do with audio! ;-)
arnyk is offline
post #18 of 22 Old 02-06-2014, 06:04 PM
gnk1's Avatar
Do tell!
gnk1 is offline
post #19 of 22 Old 02-06-2014, 06:25 PM
SAM64's Avatar
Liked: 78
...if I started posting....
lol...when did you stop?
We get it arny , you know all there is to know about all things electronic......hence your continued posting to this well respected, highly esteemed forum of high tech.....where 90 % of the posts are about cables wink.gif
SAM64 is offline
post #20 of 22 Old 02-07-2014, 04:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
That's just it, you don't know what my area of greatest interest or knowledge is. It is violently OT here. Trust me, it ain't consumer audio or even audio at all.
We get it Arny , you know all there is to know about all things electronic......hence your continued posting to this well respected, highly esteemed forum of high tech.....where 90 % of the posts are about cables wink.gif
We must be logged into different sites. ;-)
Most of the posts I see and answer are from newbies who just shot themselves in the foot while setting an AV system.
arnyk is offline
post #21 of 22 Old 02-07-2014, 05:33 AM
SAM64's Avatar
Liked: 78
...and you don't know mine. You just assume you do.
And trust me, I have knowledge and experience that you clearly lack.
...then don't you feel your talents are wasted, answering questions about conductors?
SAM64 is offline
post #22 of 22 Old 02-08-2014, 02:49 PM
CharlesJ's Avatar
Quoted: 460 Post(s)
Liked: 277
CharlesJ is offline
Reply 2-Channel Audio
