new 2-channel system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-08-2014, 02:36 PM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
hi, new to the forum. i'm wanting to start a new 2-channel setup. i am on a limited budget so this is what i have now. i bought a refurb onkyo TX8020 from A4L, 2 new monitor 30's from newegg, and 2 refurb monitor 45bs from polk audio. i already had the monitor 30's and i added the monitor 45'bs for more dispersion and louder sound for a 4 speaker system for music only. the TX8020 can drive the 4 speakers so i'm looking some opinions on where to put the monitor 30's..... in the rear of the room or put all 4 in the front. i have big bookcases on either side of my tv in a room about 15x18ft in size. thanks for your advice and happy to be a new member!
mains-POLK RTI6
center-POLK CSI3
surround-POLK RC65 INWALL
sub-DAYTON 1200
receiver-YAMAHA RX-V475
riley08 is offline
post #2 of 11 Old 02-08-2014, 04:35 PM
postrokfan's Avatar
Quoted: 524 Post(s)
Liked: 3136
I'm not sure how well the 45bs will blend with the 30s since they're the newly redesigned model. I'm not sure the locations of the speakers are that important. You could have all four in front or on the four corners of your main listening position. I would experiment with different amounts of toe-in as well.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 11 Old 02-08-2014, 04:39 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Sell one pair of speakers. You'll get better sound from one pair than from two.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 11 Old 02-08-2014, 09:48 PM
MrAcoustat's Avatar
Liked: 30
Agree 100% sometimes to much is like not enough , keep the best and sell the other.
Chord CPM-2600 amplifier
Chord One cd player
Acoustat 1+1 speakers
Life without Acoustat is possible but WHY.
MrAcoustat is offline
post #5 of 11 Old 02-09-2014, 12:45 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
2 Pairs or 1 pair, really depends on how you listen to music, if you like to "see" the performance then 2 speakers would be required, but if you like your system to have a "Club" like atmosphere, then 4 speakers around the room would be ideal. Adding a subwoofer would also be a good investment
qguy is offline
post #6 of 11 Old 02-09-2014, 07:26 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1686
Mcnarus is correct. If you insist on using 4 speakers put one pair right on top of the other or right next to the other to reduce phase cancellation. It will still sound worse than simply using one pair of speakers.
FMW is offline
post #7 of 11 Old 02-09-2014, 08:51 AM
Stanton's Avatar
Quoted: 1424 Post(s)
Liked: 748
Hate to say it, but you might have saved yourself from $$ by asking BEFORE you bought anything. The only thing 4 speakers are good for is as part of a 5.1 movie system (and you're still missing the key center channel); as mentioned, they won't do you much good on the music side of things. Also, I hope that Onkyo doesn't overheat if you're going to drive all 4 at high volumes (it was a refurb after all).
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #8 of 11 Old 02-09-2014, 08:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
+1
arnyk is offline
post #9 of 11 Old 02-09-2014, 09:43 AM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
i'm getting the message. i will use the 45B's and my son who lives in a apt will take the 30's!
mains-POLK RTI6
center-POLK CSI3
sub-DAYTON 1200
riley08 is offline
post #10 of 11 Old 02-09-2014, 10:16 AM
postrokfan's Avatar
Quoted: 524 Post(s)
Liked: 3136
Probably a good call. Enjoy!
post #11 of 11 Old 02-09-2014, 06:39 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
lulimet is offline
Reply 2-Channel Audio
