Advice on TT please. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-28-2014, 10:11 PM - Thread Starter
David Susilo's Avatar
Quoted: 636 Post(s)
Liked: 592
I currently am using Technics SL-2000 with Ortofon OM10 cart/stylus combo, Rek-o-Kut mkIII phono pre-amp, Pioneer Elite SC-75 receiver, with PSB Century 300i speakers. I'm very happy with the sound.
However, is it advisable for me to "upgrade" to Rega RP-1 with Ortofon OM5? Or should I go to Marantz TT-15s before I can really hear the sound upgrade?
Thank you very much beforehand.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2 of 18 Old 03-29-2014, 12:38 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
A second hand non DJ'd SL1200 would be an upgrade. Regas are way over rated.
But if you're happy, why change?
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #3 of 18 Old 03-29-2014, 04:27 AM
lefthandluke's Avatar
Quoted: 138 Post(s)
Liked: 282
...please explain
at the zenith of his nadir...
lefthandluke is offline
post #4 of 18 Old 03-29-2014, 04:48 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
...please explain
I have one, and for all the world it looks to me like a circa 1960s AR turntable with a glass platter. The tone arm from another manufacturer is far better than the AR arm.
it is an OK TT, but nothing to write home about. Of course what can you do with something that is condemned to spin mere vinyl for the rest of its life? ;-)
arnyk is offline
post #5 of 18 Old 03-29-2014, 03:10 PM
A9X-308's Avatar
Liked: 1142
...please explain
I've had 2. They're just not that good especially for the money they charge. I agree with Arny's synopsis.
A9X-308 is offline
post #6 of 18 Old 03-29-2014, 03:14 PM - Thread Starter
Quoted: 636 Post(s)
Liked: 592
So in your opinion I should stay with my SL2000 instead of going with RP1 (I can get a refurbished one for $300).
As for the TT15s, it doesn't dazzle me (it's not worth the $1700 price, IMHO)
my home theatre
post #7 of 18 Old 03-29-2014, 03:43 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Best bet call Jay at Audio Revelations, let him know your budget and he'll get your sorted. Great deals on refurbished Sota tables.
http://www.audiorevelation.com/cre/category.php?cPath=31
trans_lux is offline
post #8 of 18 Old 03-29-2014, 04:29 PM
A9X-308's Avatar
Liked: 1142
I wouldn't bother.
A9X-308 is offline
post #9 of 18 Old 03-29-2014, 05:12 PM - Thread Starter
Quoted: 636 Post(s)
Liked: 592
Thank you!
my home theatre
post #10 of 18 Old 03-29-2014, 07:49 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
The last thing you need is to upgrade your turntable. Upgrade the cartridge, if you want to spend some dough. Or send the table to www.kabusa.com and have Kevin add a fluid damper for the tonearm.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #11 of 18 Old 03-29-2014, 08:50 PM - Thread Starter
Quoted: 636 Post(s)
Liked: 592
How about upgrading my ortofon OM10 to OM40?
my home theatre
post #12 of 18 Old 03-29-2014, 09:13 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
post #13 of 18 Old 03-29-2014, 10:29 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 80
You can swap in the 20, 30, or 40 stylus into your current OM10 cartridge body. The 20 is supposed to be a nice improvement over the 10, with the 30 and 40 being better yet. But I have not personally compared them. I do wonder whether your SL-2000's tonearm might be too low-compliance (too heavy) to work well with the higherr-compliance 20/30/40 stylii.
skriefal is offline
post #14 of 18 Old 03-30-2014, 10:23 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Relevant specs:
SL1200 arm wt.: 12g
OM40 wt.: 5g
OM40 compliance: 25 uM/uN
Resonant freq.: 7.7 Hz
A shade lower than ideal, but should work fine.
mcnarus is offline
post #15 of 18 Old 03-30-2014, 12:56 PM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
Originally Posted by mcnarus View Post
Relevant specs:
SL1200 arm wt.: 12g
OM40 wt.: 5g
The SL2000 has an entirely different tonearm than the SL1200.
jdcrox is offline
post #16 of 18 Old 03-30-2014, 02:27 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Oops. Brain freeze.
I can't find an effective mass for the 2000 arm. If it's substantially heavier, that would be a problem. The fact that he's currently running it with an OM10, however, suggests that it would not be.
mcnarus is offline
post #17 of 18 Old 03-31-2014, 05:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Oops. Brain freeze.
The SL2000 users manual seems to be no help.
If you have both tonearms on hand and can remove the counterweights, comparing their weights can get you into the ballpark.
David Susilo likes this.
arnyk is offline
post #18 of 18 Old 03-31-2014, 12:17 PM
Tweaked05's Avatar
Quoted: 46 Post(s)
Liked: 34
I don't have the experience that some of these guys have with other TT's, but I can tell you my experience with my RP-1. I love it. It is quiet, It spins at a consistent 33 1/3 rpm's so I hear little to no wow or flutter. The tone are is one of their own design and uses a proprietary composite material. I think it's a fantastic TT. I wouldn't hesitate to recommend it.
Tweaked05 is offline
Reply 2-Channel Audio
