Nakamichi clock radio replacement - AVS Forum
post #1 of 3 Old 03-30-2014, 01:57 PM - Thread Starter
mark905's Avatar
Our Nakamichi 1 clock radio -- with the satellite that included a speaker / clock display / limited buttons -- just died. With a king-sized bed, having that second clock display was really ideal. The audio quality was quite adequate for what we listen to and the tuner performed well enough. We've had it for 20 years, so I guess its time was up. Is there something available to replace it nowadays? In particular, I am looking for a clock radio (AM required, internet OK) with a second clock display in a satellite unit (either wired or wireless) that we can put on the other side of the bed. Any recommendations? Thanks!
mark905 is offline
post #2 of 3 Old 04-01-2014, 07:40 AM
commsysman's Avatar
Quoted: 134 Post(s)
Liked: 257
The Phillips DC390 is a very nice unit that you may want to look at.
I still have a Nakamichi 1, and they are a unique product.
The Tivoli Audio Model 10 and Model 2 are probably the closest thing on the market to the Nakamichi.
Check the Tivoli Audio website.
None of the satellites have a clock, though; clocks are cheap...lol.
commsysman is offline
post #3 of 3 Old 04-10-2014, 10:41 AM
NormP's Avatar
My Nak 1 gave up the fight years ago, I never found anything that could replace it.
Norm
NormP is offline
Reply 2 Channel Audio
User Tag List
