OPPO PM-1 Planar Magnetic Headphones - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 112 Old 07-28-2014, 10:39 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 622
^ That brings up a good point though, about Oppo and how they have a 30 day return policy.
You can buy and then if you don't like them, just return for a full refund within 30 days and you are only out the shipping charges.
I don't know of any other OEM of these types of products that offers such a generous return policy.
Smarty-pants is offline
post #92 of 112 Old 07-29-2014, 05:46 PM
Berland's Avatar
Quoted: 44 Post(s)
Liked: 29
Originally Posted by Smarty-pants View Post
I think the unbalanced headphone outputs will be very close to the same, but the balanced will sound quite a bit better.
It also of course depends on what headphones you are using. You will need some very high quality cans like the PM-1 or PM-2 to hear the difference.
I think the balanced output are superior to the unbalanced on the Oppo HA-1; even at matching audio level. The balanced just sounds better.
HT: CLASSE CA-5300 DELTA - BRYSTON 4B SST2 - Marantz AV8802A - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2, SA Talent - NORDOST Heimdall 2 (signal), Frey2/Heimdall2 (power), Frey2 (speaker) - ISOTEK EVO3 Titan,Sigmas - Samsung UE78JS9505 - GIK ACOUSTICS - AUDYSSEY Pro Kit
HP: 2*MOON Neo 430HA D - Schiit Yggdrasil - Audiobyte Hydra Z, Hydra ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, LCD-3F, 2*LCD-XC - SHURE SE846
Berland is offline
post #93 of 112 Old 07-30-2014, 11:53 PM
dmusoke's Avatar
Quoted: 265 Post(s)
Liked: 140
This is what Oppo says about the HA-1 ".... All single-ended outputs are derived from the balanced signal as well...."
This means the SE output is derived from the positive leg of the balanced output, so how can the SE output sound inferior to the balanced output since its the same signal? Just curious...
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #94 of 112 Old 07-31-2014, 01:28 AM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
It's magic.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #95 of 112 Old 07-31-2014, 04:59 AM
Berland's Avatar
Quoted: 44 Post(s)
Liked: 29
It is the same signal; but only half of it By switching between balanced and unbalanced output (with same headphones; I could with ease hear which output is being used). Just tested by having another person selecting output and setting matching volume level. (pausing the music during switch and volume adjustment).
Edit:
Keep in mind that balanced is not only lower noise levels; also increased dynamic range.
Berland is offline
post #96 of 112 Old 08-22-2014, 06:40 AM
Super Moderator
markrubin's Avatar
Quoted: 1037 Post(s)
Liked: 2274
anyone try the alternative Lambskin Leather Earpads?
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #97 of 112 Old 08-22-2014, 07:47 AM
Quoted: 747 Post(s)
Liked: 622
Here's some info from using all of the PM-1 pads on the PM-2.
More info from Tyll on using them with the PM-1 soon.
http://www.innerfidelity.com/content...d-measurements
post #98 of 112 Old 08-22-2014, 07:52 AM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
I have. I prefer them. The sound is more open on the high end and seems a bit more defined in the lows.
There is a good comparison with measurement in Innerfidelity:
The difference sounded more pronounced than the measurements might look, but then again the scale is pretty large.
If you have PM-1s, I recommend signing up for them.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #99 of 112 Old 11-28-2014, 08:24 AM
SoundSmile's Avatar
I just picked up a set of the PM-1 headphones a couple of days ago.
These are my opinions thus far. Feel free to agree or disagree! This is more of a first impression than anything. I am really pleased with the purchase and grow more so as I spend time with them.
Sources: various sites and media across my PC utilizing an HRT microStreamer as well as some time with my OPPO BD-105
I was a bit dissapointed with the BD-105 headphone amp. A bit dull and lifeless versus the HRT.
In that I haven't spent much time with recent high end cans, I will have to compare these to my Wilson Watt Puppies. Sorry for that!
Pros
Smooth
Fast
Neutral
Non-analytic
Extreme comfort
Detailed
Absolutely effortless
Micro-details are clear and precise
Cons
Versus the W/P - they lack the base punch - this may be the fault of the lack of a real amplifier.
Summary
Very easy to listen to for hours on end with no fatigue whatsoever. I keep wanting to hear just one more cut.
I preferred the sound and comfort of the velour pads over that of the lambskin set. Not by very much though. Both are viable options and I will probably spend more time investigating this in the near future.
Notes
Once the holiday mess has settled I expect I will purchase an HA-1 and a balanced cable. I expect that this will really be a boon to such a pleasurable headset. More to come as I get more time on them and decent amplification.
I do want to stress that the HRT really does shine with these if you are in the market for an affordable/portable USB DAC amp device.
SoundSmile is offline
post #100 of 112 Old 01-01-2015, 06:47 PM
jimshowalter's Avatar
Quoted: 49 Post(s)
Liked: 52
Originally Posted by RayDunzl View Post
It's magic.
It's measurable magic--check the side-by-side spec comparison on Oppo's site for the HA-1's headphone outputs, XLR vs. RCA.
My system? Google for: Martin Logan 420 CLX Descent Stage Summit
jimshowalter is offline
post #101 of 112 Old 01-01-2015, 06:53 PM
Quoted: 49 Post(s)
Liked: 52
I have a pair of these excellent headphones.
Now I want to get a stand for them.
Has anyone tried a Sieveking Omega with the PM-1s?
I like the way it looks better than the plastic stand from Oppo, but (presumably) the stand from Oppo fits the contour exactly. The measurements for the Omega show it at least a half inch narrower than the chord across the PM-1's headband. Which means for all the graceful bentwood construction of the Omega, it might be not much better than hanging them off a coathanger (because if the contour doesn't match, then the weight isn't evenly distributed on the curve, only on the apex).
post #102 of 112 Old 01-05-2015, 11:24 AM
Quoted: 49 Post(s)
Liked: 52
I asked the same question on head-fi and a person tried their PM-1s with an Omega. They said it fit okay, but only if they expanded the headband all the way, otherwise it pinched the cups. So no Omega for me. Ordered a stand from Oppo.
post #103 of 112 Old 01-06-2015, 02:41 AM
Quoted: 49 Post(s)
Liked: 52
Picked up the stand today. Fits perfectly. And looks way better in person than it looks in any photos I've seen.
post #104 of 112 Old 04-12-2015, 12:42 PM
Quoted: 675 Post(s)
Liked: 97
Hi
I have three questions regarding pm2. Could anyone help me with this?
1. Can I just plug into my receiver to listen to my movie w/o buying oppo's HA amplifier?
2. Can you hear 5.1 like surrounding sound using pm2? or pm2 is just for two channel stereo music?
3. Does it have longer than 16.2 ft (5 meters) cable? or even wireless?
Roudan is online now
post #105 of 112 Old 04-12-2015, 02:21 PM
Quoted: 747 Post(s)
Liked: 622
Originally Posted by Roudan View Post
Hi
1) Yes, as long as your processor has a headphone output.
2) The Oppo headphones are designed for 2-channel audio, and devices like a BDP-105D or your receiver
are designed to downmix any multi-channel audio to 2-channel audio before outputting said audio over
the headphone output. The quality of sound out of any given headphone output is dependent on any given
piece of gear and the engineering and construction of said gear.
3) No, but you can buy longer aftermarket cables that will work the headphones, and prices range from
inexpensive to very expensive. The Oppo headphones are not wireless capable either, but again there
are aftermarket device that you can place between the headphones and audio device that can render
wireless capabilities. Usually most devices like that will downgrade/compress the quality of audio though.
Roudan likes this.
post #106 of 112 Old 04-13-2015, 07:20 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
Originally Posted by wse View Post
Quote:Originally Posted by Jack D Ripper At $1099, they need to sound absolutely great to be a good deal. And the way Oppo tends to do business, there are not likely to be any special sale prices ever on new units, so that is the street price.  It will be interesting to read some reviews when they come out.
Yes it will be interesting if they are worth the full MSRP!
well? are they?
eljr is offline
post #107 of 112 Old 04-13-2015, 07:23 AM
eljr's Avatar
Liked: 8025
Is this the stand you picked up today? Sieveking Omega
eljr is offline
post #108 of 112 Old 04-13-2015, 11:46 AM
Quoted: 49 Post(s)
Liked: 52
No, I got the one from Oppo.
eljr likes this.
post #109 of 112 Old 04-13-2015, 12:02 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
well? are they?
No personal experience but you may want to check out the Hi Fi Man HE series headphones. The HE400 is my avatar. They are also planar magnetics, perform very well and are about half the price of the Oppo. It would be a great comparison, although one I haven't made personally.
eljr likes this.
FMW is offline
post #110 of 112 Old 04-13-2015, 12:22 PM
eljr's Avatar
Liked: 8025
I have the HE500 on order a few weeks now based on your avatar and previous conversations with you. Should have them by next week. I was going to go with the HE400 but with these models discontinued I was able to pass on the Oppo PM1 and get the HE500, PSB M4U 1 High Performance (highly regarded) and I have $300 left for ear phones for my Pono for walking in the park.
Any suggestions on the Pono buds? I have a thread here. Don't really like the suggestions yet.
(the PSB are not yet ordered, have them on my watch list)
eljr is offline
post #111 of 112 Old 07-06-2015, 02:47 PM
classicrecording's Avatar
Quoted: 46 Post(s)
Liked: 93
Igor Levitsky of Oppo Digital discusses Headphone Technology
http://www.hifiplus.com/articles/igo...ne-technology/
classicrecording is offline
post #112 of 112 Old 07-06-2015, 03:03 PM
Quoted: 747 Post(s)
Liked: 622
Originally Posted by classicrecording View Post
Nice! TY!
Reply 2-Channel Audio
