MK subwoofer pumping with phono - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2014, 02:11 PM - Thread Starter
Buffordlee's Avatar
Hey there I have an older M&K subwoofer The Volkswoofer and it sounds and plays great recently added a Project Music Hall 2.2 turntable to my system and all seemed fine, now the subwoofer is pumping when playing the Phono, I have an Acurus CD player and the MK is fine when it's Playing my preamp is a Sherbourne 1, eventually the sub will start to sound like a helicopter when playing vinyl  Please help
Buffordlee is offline
Old 04-16-2014, 02:33 PM
Ratman's Avatar
Quoted: 1277 Post(s)
Liked: 1026
Who "setup" your TT? I'd take a stab that something is not weighted, aligned, yada, yada, properly.
In other words, look to the TT and not the "system" (since all works well).
My initial guess would be subsonic "wow" that is possible due to poor setup and/or cabling.
Buffordlee likes this.
Ratman is online now
Old 04-16-2014, 02:40 PM - Thread Starter
Buffordlee's Avatar
Well I would be the one on set up cart come factory set up, I also have a BIC F12 sub in the same set up it play fines, I have played around a little with the weight adjustment with no luck and different records Thanks
Old 04-16-2014, 03:07 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Acoustic feedback.
(1) Improve the isolation between the TT and the subwoofer which may require acoustic or mechanical isolation. Sometimes closing the cover on the TT can help..
(2) Simply add an switchable electrical high pass filter, probably between the preamp and the power amp.
A useful alternative would be found on this page in the form of an Harrison FMOD:
http://www.parts-express.com/cat/in-line-crossovers/405
You want the lowest frequency rated item that is still effective, which is impossible to predict over the web.
arnyk is offline
Old 04-16-2014, 04:19 PM - Thread Starter
Buffordlee's Avatar
Thank you for your response I don't that great of a system but I enjoy it greatly it really sounds good to us I will try the sloping crossover Thanks again
Old 04-16-2014, 04:20 PM
Ratman's Avatar
Liked: 1026
So you have two subs, a new TT, an one sub has a problem and the other doesn't?
Old 04-16-2014, 06:19 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
In most setups, it is impossible to prevent acoustic feedback from the subwoofer to the turntable.
When you have a warped record, or extreme low bass content on the record, it is very tough to isolate the turntable enough to prevent a microphonic oscillation from occuring.
I have to turn off my subwoofer on a number of records; that is all one can do.
If your main speakers go low enough, that should not be a problem.
The problem is much worse with a "live' floor than a concrete slab floor.
commsysman is offline
Old 04-16-2014, 06:41 PM - Thread Starter
Buffordlee's Avatar
Yes I have 2 I run a set of CM2 off of the Bic and a set of CM1 off the M&K and I have 4 MA500 Marantz amps to run them, I know a weird set up but you get what you can Thanks
Old 04-16-2014, 06:45 PM - Thread Starter
Buffordlee's Avatar
Your right by all accounts raised floor and it started with a not so flat record, but it seems like I must shut it down for several minutes to get it right again, I think I'm going your route and install a switch to shut it down while playing vinyl I have a Bic sub in another location that does fine on LPs I think I can live without the M&K on records Thanks a bunch
Old 04-24-2014, 07:52 AM
Dezmond's Avatar
Probably need a low cut or subsonic filter.
Dezmond is offline
Old 04-24-2014, 03:40 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Definitely needs a HPF. Try 20Hz > 2nd order.
A9X-308 is offline
